Thanks so much for the scripts! The only one I hadn't used before was the one to clean out the Reports folder. That will free up a lot of my Monday time.
Thanks again!
Jill Schoedel
Network Systems Coordinator
Metalworks
Thanks again!
Jill Schoedel
Metalworks
--- In vantage@yahoogroups.com, "Len Hartka" <len.hartka@...> wrote:
> Good Day:
> Me also len.hartka@...
> Len
> Of Ken Williams
> Sent: Thursday, February 03, 2011 9:54 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Epicor 9 down to a crawl ..... SOLVED - Email
> found in subject
> If you can post to the group file that would be greatly appreciated.
> Otherwise please copy me as well on the script.
> Thanks,
> Ken Williams
> Creating customer confidence through extraordinary service and
> experienced industry experts.
> -----Original Message-----
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of effgroups@... <mailto:effgroups%40gmail.com>
> Sent: Thursday, February 03, 2011 5:19 AM
> Subject: Re: [Vantage] Epicor 9 down to a crawl ..... SOLVED - Email
> found in subject
> Hi Chris
> Unfortunately the group doesn't forward attachments.
> So either you email it to me directly or you post it in the group file
> section.
> thanks
> Ephraim Feldman
> Programmer / Analyst
> Axis Lighting
> From: Chris Thompson <chriselectrix@...
> <mailto:chriselectrix%40ymail.com> >
> Sender: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> Date: Thu, 3 Feb 2011 09:50:33
> To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
> Reply-To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> I have attached the instructions.
> Please let me know if you have any questions.
> From: Ephraim Feldman <effgroups@...
> <mailto:effgroups%40gmail.com> >
> Sent: Wed, 2 February, 2011 16:47:38
> We are on Progress
> i would appreceate if you would share this script with me.
> We are on Windows 2008 server
> On Tue, Feb 1, 2011 at 10:16 AM, Chris Thompson <chriselectrix@...
> <mailto:chriselectrix%40ymail.com> >wrote:
> > From what I know, the temp files can be created if processes are
> interupted
> > (such as sever not been shut down when processes were running).
> > I would recommend running a script to clear out the temp files on a
> regular
> > basis. Of course adding and removing files regularly mashes up your
> hard
> > drive
> > so it's also advisable to defrag your hard drives weekly.
> > I have a script that does all of this weekly as we used to have
> slow-downs.
> > Since implementing it, we havent had one single issue in about 9-12
> months
> > related to speed.
> > Are you progress or SQL?
> > Thanks.
> <mailto:effgroups%40gmail.com> <effgroups%40gmail.com>>
> <vantage%40yahoogroups.com>
> > Sent: Thu, 27 January, 2011 19:20:28
> > Subject: [Vantage] Epicor 9 down to a crawl ..... SOLVED
> > Hi all
> > We experienced a sudden slowdown beginning of this week and finally
> solved
> > it and i want to share it with the group.
> > We upgraded our server about 6 months ago to accommodate Epicor 9 and
> we
> > where really happy with the speed of epicor running on the new server.
> > Suddenly beginning of this week we started experiencing slowdowns that
> > almost brought us to a halt. i tried restarting the server but to no
> avail.
> > Our first guess was that since we changed our switches over the
> weekend
> > this
> > would be the issue and we tested epicor directly on the server and it
> was
> > working relatively fast so we where sure that the network connection
> is the
> > issue.
> > We called in our network guy and we ran various tests and we saw that
> the
> > network throughput is very good and we don't even utilise 1% of it so
> we
> > had
> > to find other things that can slow down the system.
> > We did think that its a result of upgrading to patch level 9.04.507A 2
> > weeks
> > ago but we checked trough all settings and it was fine.
> > The last thing (as always) i reminded myself reading here on the group
> a
> > while ago about cleaning the temp files so i went and checked our
> > epicor904data directory and it was about 25 GB and when i looked into
> this
> > there was so temp files in the root of the folder the size of 1.3 GB
> each.
> > So i backed up that folder then shut down the appservers and deleted
> all
> > files in that folder then restarted the system and once i did that all
> got
> > back to speed ...........
> > So my question is what causes these files to grow out of proportion?
> and is
> > it pure coincidence that it happened when we changed switches? maybe
> the
> > server was not shut down properly while the network guy did his job?
> > Any thoughts on this would be appreciated.
> > Ephraim
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> have already linked your email address to a yahoo id to enable access. )
> and Crystal Reports and other 'goodies', please goto:
> This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
