Epicor 9 - Problems Printing Some Customised Reports
vantage@yahoogroups.com wrote:
> I do have A document but not sure if it is any use.
Bernie Walker and I have been talking offline and the Progress edition
appears to be the V8 version with some simple Find/Replace operations and
really doesn't add anything E9 specific. In fact, it still talks about
"Vista/Vantage", not Epicor 9. Also, it references OE101B in the document
where E9 runs on OE101C.
Mark W.
Hi All,
We have recently upgraded to Epicor 9 from Vantage 8 and have a problem printing our customised reports.
Firstly, some table names had changes so I have sorted those in Crystal.
The problem that we have is when you go to preview a report, it gives the following error ...
Error Detail
Exception of type 'System.OutOfMemoryException' was thrown.
Stack Trace
  at System.String.Concat(String str0, String str1)
  at Epicor.Mfg.BO.ReportMonitor.TransferReport(String sysRowID, String dataPath, String definitionPath)
  at Epicor.Mfg.UI.Adapters.ReportMonitorAdapter.TransferReport(String sysRowID, String fileNameData, String fileNameRepDef)
When you click OK to that, you get the following error ...
Error Detail
Load report failed.
Stack Trace
  at CrystalDecisions.ReportAppServer.ReportClientDocumentWrapper.EnsureDocumentIsOpened()
  at CrystalDecisions.CrystalReports.Engine.ReportDocument.Load(String filename, OpenReportMethod openMethod, Int16 parentJob)
  at CrystalDecisions.CrystalReports.Engine.ReportDocument.Load(String filename, OpenReportMethod openMethod)
  at Epicor.Mfg.Lib.Report.EpiCrystalViewer.LoadReport(Object state)
Inner Exception
The system cannot find the file specified.
Inner Stack Trace
  at CrystalDecisions.ReportAppServer.ClientDoc.ReportClientDocumentClass.Open(Object& DocumentPath, Int32 Options)
  at CrystalDecisions.ReportAppServer.ReportClientDocumentWrapper.Open(Object& DocumentPath, Int32 Options)
The reports used to work on Vantage 8 perfectly.
The standard reports run - it only appears to be customised reports.
The reports are only approx 6mb in size (due to logos etc) and nothing else is running on the PC when printing the reports.
We have tried this on several PCs and all of them give the error.
The error only happens 75% of the time - other times, the reports will run and open perfectly which suggests the Crystal Report and Data Definition etc are all OK.
Any help or info on similar experiences would be appreciated.
Cheers,
CHRIS THOMPSON
Are you a progress or SQL database?
Blake Clemens
DMC
Of Chris Thompson
Sent: Friday, June 12, 2009 8:06 AM
Subject: [Vantage] Epicor 9 - Problems Printing Some Customised Reports
Hi All,
Error Detail
Stack Trace
Error Detail
Load report failed.
Stack Trace
at
entIsOpened()
Inner Exception
Inner Stack Trace
at
at
at
entIsOpened()
Cheers,
CHRIS THOMPSON
Hi Blake,
We are using Progress.
It is almost as if the services that handle the printing are allocated enough memory as it seems to go on the size of report whether they rpint or don't.
Any help would be appreciated.
Cheers,
CHRIS THOMPSON
Sent: Friday, 12 June, 2009 13:23:46
Subject: RE: [Vantage] Epicor 9 - Problems Printing Some Customised Reports
Blake Clemens
DMC
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Chris Thompson
To: vantage@yahoogroups .com
Hi All,
Error Detail
Exception of type 'System.OutOfMemory Exception' was thrown.
Stack Trace
at System.String. Concat(String str0, String str1)
at Epicor.Mfg.BO. ReportMonitor. TransferReport( String sysRowID, String
at Epicor.Mfg.UI. Adapters. ReportMonitorAda pter.TransferRep ort(String
Error Detail
Load report failed.
Stack Trace
at
CrystalDecisions. ReportAppServer. ReportClientDocu mentWrapper. EnsureDocum
entIsOpened( )
at CrystalDecisions. CrystalReports. Engine.ReportDoc ument.Load( String
at Epicor.Mfg.Lib. Report.EpiCrysta lViewer.LoadRepo rt(Object state)
Inner Exception
Inner Stack Trace
at
CrystalDecisions. ReportAppServer. ClientDoc. ReportClientDocu mentClass. Ope
at
CrystalDecisions. ReportAppServer. ReportClientDocu mentWrapper. Open(Object
at
entIsOpened( )
Cheers,
CHRIS THOMPSON
This problem sounds familiar to me but I haven't had to deal with it in
a while. Are your Progress settings correctly set up on the server? It
seems like Progress needs more resources allocated to it. Maybe Vantage
goofed up again with their Epicor 9 requirements/settings like they did
with version 8. Did you exceed the required hardware specifications for
Epicor 9?
Blake Clemens
DMC
Of Chris Thompson
Sent: Friday, June 12, 2009 8:44 AM
Subject: Re: [Vantage] Epicor 9 - Problems Printing Some Customised
Reports
Hi Blake,
or don't.
Cheers,
CHRIS THOMPSON
<mailto:blake.clemens%40d-m-c.com> >
Reports
Blake Clemens
DMC
Behalf
Of Chris Thompson
Hi All,
Error Detail
Stack Trace
Error Detail
Load report failed.
Stack Trace
at
EnsureDocum
entIsOpened( )
Inner Exception
Inner Stack Trace
at
mentClass. Ope
at
Open(Object
at
EnsureDocum
entIsOpened( )
Cheers,
CHRIS THOMPSON
If these custom reports run VIA ODBC you may be running up against that ODBC
size limit. I know the fix for that has been thrown around a couple of
times. I didn't have much luck with it though.
~Charlie
_____
Chris Thompson
Subject: Re: [Vantage] Epicor 9 - Problems Printing Some Customised Reports
Hi Blake,
don't.
Cheers,
CHRIS THOMPSON
From: Blake Clemens <blake.clemens@ <mailto:blake.clemens%40d-m-c.com>
d-m-c.com>
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Blake Clemens
DMC
Of Chris Thompson
Hi All,
Error Detail
Stack Trace
Error Detail
Load report failed.
Stack Trace
at
entIsOpened( )
Inner Exception
Inner Stack Trace
at
Ope
at
at
entIsOpened( )
Cheers,
CHRIS THOMPSON
Hi Blake,
Our servers are as per the latest hardware requirements spec.
Everything else runs well, it only seems the 'larger' reports that dont.
I would have thought there would be a setting somewhere to allocate more memory to certain processes.
Cheers,
CHRIS
Sent: Friday, 12 June, 2009 13:50:02
goofed up again with their Epicor 9 requirements/ settings like they did
Epicor 9?
Blake Clemens
DMC
Of Chris Thompson
Reports
Hi Blake,
or don't.
Cheers,
CHRIS THOMPSON
<mailto:blake. clemens%40d- m-c.com> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Reports
Blake Clemens
DMC
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
Behalf
Of Chris Thompson
Hi All,
Error Detail
Stack Trace
Error Detail
Load report failed.
Stack Trace
at
EnsureDocum
entIsOpened( )
Inner Exception
Inner Stack Trace
at
mentClass. Ope
at
Open(Object
at
EnsureDocum
entIsOpened( )
Cheers,
CHRIS THOMPSON
In your Progress Explorer Tool-Databases... have you messed around with
adding more servers to your ODBC group? Or allocating more/less users
per server in the ODBC Group? Just thinking out loud here. Is it the
same reports that don't work or does it just happen sporadically to all
customized reports?
Blake Clemens
DMC
Of Chris Thompson
Sent: Friday, June 12, 2009 8:55 AM
Reports
Hi Blake,
Cheers,
CHRIS
Reports
Epicor 9?
Blake Clemens
DMC
Behalf
Of Chris Thompson
Reports
Hi Blake,
or don't.
Cheers,
CHRIS THOMPSON
Reports
Blake Clemens
DMC
Behalf
Of Chris Thompson
Hi All,
Error Detail
Stack Trace
Error Detail
Load report failed.
Stack Trace
at
EnsureDocum
entIsOpened( )
Inner Exception
Inner Stack Trace
at
mentClass. Ope
at
Open(Object
at
EnsureDocum
entIsOpened( )
Cheers,
CHRIS THOMPSON
Hi Charlie,
It is a S O Acknowledgement - is that ODBC?
Not really sure what OSBC is.
Sent: Friday, 12 June, 2009 13:50:28
~Charlie
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Chris Thompson
Hi Blake,
don't.
Cheers,
CHRIS THOMPSON
From: Blake Clemens <blake.clemens@ <mailto:blake. clemens%40d- m-c.com>
d-m-c.com>
To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
Blake Clemens
DMC
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
Of Chris Thompson
Hi All,
Error Detail
Stack Trace
Error Detail
Load report failed.
Stack Trace
at
entIsOpened( )
Inner Exception
Inner Stack Trace
at
Ope
at
at
entIsOpened( )
Cheers,
CHRIS THOMPSON
I havent messed with any settings (whether Epicor have them set correctly is another story).
It is only the larger reports that we are having issues with.
Sometimes, the reports will run, but if you try them again you can put money on them not running for several more times.
Sent: Friday, 12 June, 2009 14:03:21
In your Progress Explorer Tool-Databases. .. have you messed around with
customized reports?
Blake Clemens
DMC
Of Chris Thompson
Reports
Hi Blake,
Cheers,
CHRIS
Reports
Epicor 9?
Blake Clemens
DMC
Behalf
Of Chris Thompson
Reports
Hi Blake,
or don't.
Cheers,
CHRIS THOMPSON
Reports
Blake Clemens
DMC
Behalf
Of Chris Thompson
Hi All,
Error Detail
Stack Trace
Error Detail
Load report failed.
Stack Trace
at
EnsureDocum
entIsOpened( )
Inner Exception
Inner Stack Trace
at
mentClass. Ope
at
Open(Object
at
EnsureDocum
entIsOpened( )
Cheers,
CHRIS THOMPSON
If it one of the canned reports from Epicor it most likely is not ODBC.
In computing, Open Database Connectivity (ODBC) provides a standard software
API method for using database management systems (DBMS). The designers of
ODBC aimed to make it independent of programming languages, database
systems, and operating systems.
Basically it is a means of connecting crystal to the Epicor 9 Database that
allows crystal to extract data from Epicor 9.
The mass majority of the stock epicor reports however use a combination of
BAQs, and report data definitions to extract the data and then an XML file
is generated that is read into crystal via an ADO file connection.
You can find these intermediate files in
drive:\epicor\mfgsysdata\reports\*USERNAME*\XXXXXXX.XML.
The username part will be filled with the name of the user who ran the
report. XXXXXXX will be the name of the report and then some random numbers
for example ARINVOICE1235645.XML. You need to watch the folder directly
after you run the report. The file will show up and then after a little
while it will delete itself. If you copy the file out you can open it and
view the data with your favorite XML viewer / editor.
Just a warning I'm not an Epicor 9 user but I highly doubt they changed this
whole process too much. I real 9 user can confirm or deny if they want.
~Charlie
_____
Chris Thompson
Sent: Friday, June 12, 2009 9:06 AM
Hi Charlie,
From: Charlie Wilson <foamdesigncsw@ <mailto:foamdesigncsw%40yahoo.com>
yahoo.com>
~Charlie
_____
Of
Chris Thompson
Hi Blake,
don't.
Cheers,
CHRIS THOMPSON
d-m-c.com>
Blake Clemens
DMC
Of Chris Thompson
Hi All,
Error Detail
Stack Trace
Error Detail
Load report failed.
Stack Trace
at
entIsOpened( )
Inner Exception
Inner Stack Trace
at
Ope
at
at
entIsOpened( )
Cheers,
CHRIS THOMPSON
Support has always told me to tweak the settings according to my
system's performance. I can't tell you exactly what setting and where
would need tweaked but I would contact support and ask them what areas
may need their settings changed a bit according to the problem you are
seeing. They will probably be very vague with their answer because they
don't want to take responsibility. Maybe you have done this already, I
don't know. We had problems with our settings in Version 8 and it took
us a long, long time until things started running at a tolerable pace.
Blake Clemens
DMC
Of Chris Thompson
Sent: Friday, June 12, 2009 9:12 AM
Reports
Reports
customized reports?
Blake Clemens
DMC
Behalf
Of Chris Thompson
Reports
Hi Blake,
Cheers,
CHRIS
Reports
Epicor 9?
Blake Clemens
DMC
Behalf
Of Chris Thompson
Reports
Hi Blake,
or don't.
Cheers,
CHRIS THOMPSON
Reports
Blake Clemens
DMC
Behalf
Of Chris Thompson
Hi All,
Error Detail
Stack Trace
Error Detail
Load report failed.
Stack Trace
at
EnsureDocum
entIsOpened( )
Inner Exception
Inner Stack Trace
at
mentClass. Ope
at
Open(Object
at
EnsureDocum
entIsOpened( )
Cheers,
CHRIS THOMPSON
Have they released a Performance Tuning doc for 9 yet?
~Charlie
_____
Chris Thompson
another story).
d-m-c.com>
customized reports?
Blake Clemens
DMC
Of Chris Thompson
Reports
Hi Blake,
Cheers,
CHRIS
Reports
Epicor 9?
Blake Clemens
DMC
Behalf
Of Chris Thompson
Reports
Hi Blake,
or don't.
Cheers,
CHRIS THOMPSON
Reports
Blake Clemens
DMC
Behalf
Of Chris Thompson
Hi All,
Error Detail
Stack Trace
Error Detail
Load report failed.
Stack Trace
at
EnsureDocum
entIsOpened( )
Inner Exception
Inner Stack Trace
at
mentClass. Ope
at
Open(Object
at
EnsureDocum
entIsOpened( )
Cheers,
CHRIS THOMPSON
Not that I am aware.
Sent: Friday, 12 June, 2009 14:20:39
~Charlie
_____
Chris Thompson
another story).
d-m-c.com>
customized reports?
Blake Clemens
DMC
Of Chris Thompson
Reports
Hi Blake,
Cheers,
CHRIS
Reports
Epicor 9?
Blake Clemens
DMC
Behalf
Of Chris Thompson
Reports
Hi Blake,
or don't.
Cheers,
CHRIS THOMPSON
Reports
Blake Clemens
DMC
Behalf
Of Chris Thompson
Hi All,
Error Detail
Stack Trace
Error Detail
Load report failed.
Stack Trace
at
EnsureDocum
entIsOpened( )
Inner Exception
Inner Stack Trace
at
mentClass. Ope
at
Open(Object
at
EnsureDocum
entIsOpened( )
Cheers,
CHRIS THOMPSON
Chris
whenever i've had problems running a report and the error message
contained "The system cannot find the file specified" it meant the
report file Vantage is trying to access isn't available for some reason.
Sometimes it's just a typo in the report's path defined within Vantage
or something really simple like share permissions on the target file's
folder. Sometimes the file is just plain missing.
It 's worth a quick check, even if just to eliminate it as a
possibilty.
Regards
David Atkinson
Dril-Quip (Europe) Ltd.
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...>
> From: Charlie Wilson foamdesigncsw@...
Reports
> ~Charlie
> _____
Behalf Of
> Chris Thompson
Reports
correctly is
> another story).
money
m-c.com>
> d-m-c.com>
Reports
with
all
> customized reports?
> Thanks,
> Blake Clemens
> DMC
Behalf
> Of Chris Thompson
> Reports
> Hi Blake,
dont.
more
> Cheers,
> CHRIS
> From: Blake Clemens <blake.clemens@ d-m-c.com
> Reports
in
Vantage
did
for
> Epicor 9?
> Thanks,
> Blake Clemens
> DMC
> Behalf
> Of Chris Thompson
> Reports
> Hi Blake,
rpint
> or don't.
> Cheers,
> CHRIS THOMPSON
> Reports
> Thanks,
> Blake Clemens
> DMC
> Behalf
> Of Chris Thompson
Reports
> Hi All,
problem
Crystal.
> Error Detail
> Stack Trace
String
ort(String
> Error Detail
> Load report failed.
> Stack Trace
> at
> EnsureDocum
> entIsOpened( )
String
String
> Inner Exception
> Inner Stack Trace
> at
> mentClass. Ope
> at
> Open(Object
> at
> EnsureDocum
> entIsOpened( )
> Cheers,
> CHRIS THOMPSON
Chris
possibilty.
Regards
David Atkinson
Reports
> ~Charlie
> _____
Behalf Of
> Chris Thompson
Reports
correctly is
> another story).
money
m-c.com>
> d-m-c.com>
Reports
with
all
> customized reports?
> Thanks,
> Blake Clemens
> DMC
Behalf
> Of Chris Thompson
> Reports
> Hi Blake,
dont.
more
> Cheers,
> CHRIS
> Reports
in
Vantage
did
for
> Epicor 9?
> Thanks,
> Blake Clemens
> DMC
> Behalf
> Of Chris Thompson
> Reports
> Hi Blake,
rpint
> or don't.
> Cheers,
> CHRIS THOMPSON
> Reports
> Thanks,
> Blake Clemens
> DMC
> Behalf
> Of Chris Thompson
Reports
> Hi All,
problem
Crystal.
> Error Detail
> Stack Trace
String
ort(String
> Error Detail
> Load report failed.
> Stack Trace
> at
> EnsureDocum
> entIsOpened( )
String
String
> Inner Exception
> Inner Stack Trace
> at
> mentClass. Ope
> at
> Open(Object
> at
> EnsureDocum
> entIsOpened( )
> Cheers,
> CHRIS THOMPSON
Hi David,
Those were my initial thoughts, but the report sometimes runs and sometimes doesn't which confirms the file path must be correct.
I think I have tied it down to the Crystal Report file size. If it is 560kb it runs well, if it is 3.4mb it doesn't.
By the way, I know there are a lot of David Atkinsons in the World, but do I know you?
Cheers,
CHRIS THOMPSON
Sent: Friday, 12 June, 2009 17:17:11
Subject: [Vantage] Re: Epicor 9 - Problems Printing Some Customised Reports
Chris
possibilty.
Regards
David Atkinson
--- In vantage@yahoogroups .com, Chris Thompson <chriselectrix@ ...>
> From: Charlie Wilson foamdesigncsw@ ...
Reports
> ~Charlie
> _____
Behalf Of
> Chris Thompson
Reports
correctly is
> another story).
money
m-c.com>
> d-m-c.com>
Reports
with
all
> customized reports?
> Thanks,
> Blake Clemens
> DMC
Behalf
> Of Chris Thompson
> Reports
> Hi Blake,
dont.
more
> Cheers,
> CHRIS
> Reports
in
Vantage
did
for
> Epicor 9?
> Thanks,
> Blake Clemens
> DMC
> Behalf
> Of Chris Thompson
> Reports
> Hi Blake,
rpint
> or don't.
> Cheers,
> CHRIS THOMPSON
> Reports
> Thanks,
> Blake Clemens
> DMC
> Behalf
> Of Chris Thompson
Reports
> Hi All,
problem
Crystal.
> Error Detail
> Stack Trace
String
ort(String
> Error Detail
> Load report failed.
> Stack Trace
> at
> EnsureDocum
> entIsOpened( )
String
String
> Inner Exception
> Inner Stack Trace
> at
> mentClass. Ope
> at
> Open(Object
> at
> EnsureDocum
> entIsOpened( )
> Cheers,
> CHRIS THOMPSON
Try uninstalling and reinstalling Crystal Runtime.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
312.533.4033 x8039
jason@...<mailto:jason@...>
https://epicweb.epicor.com/doc/Pages/Epicor9.aspx
One for SQL and one for Progress.
Mark W.
Sent: Sunday, 21 June, 2009 20:23:07
https://epicweb. epicor.com/ doc/Pages/ Epicor9.aspx
Mark W.
