Epicor 9 regarding receiving and lot numbers
Thanks, Brian.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Brian Roberts
Sent: Wednesday, October 31, 2012 1:22 PM
Subject: RE: [Vantage] Epicor 9 regarding receiving and lot numbers
In Part Maintenance, go to the Lot tab and a click on "Expiry Date
Required". Then Epicor will pop up a window after the receipt has been
entered, asking for the date.
To edit on lots already created, there's a Lot Maintenance screen
somewhere under inventory management.
Brian.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Mary Horsey
Sent: Wednesday, October 31, 2012 1:14 PM
Subject: [Vantage] Epicor 9 regarding receiving and lot numbers
In Vantage 6 in the receipt entry
When receiving product in you could receive the line and then you could
enter in a lot number for the part being received. If you opened up the
lot block it gave you an option of putting in an expiration date for the
I cannot find this option in Epicor 9 receipt entry. Has anyone seen
this feature at the receiving level?
Any help you can give would be greatly appreciated.
Sincerely,
Mary Horsey
When receiving product in you could receive the line and then you could enter in a lot number for the part being received. If you opened up the lot block it gave you an option of putting in an expiration date for the part being received.
I cannot find this option in Epicor 9 receipt entry. Has anyone seen this feature at the receiving level?
Sincerely,
Mary Horsey
The part must be set to have expiration dates. These can be set under the part form, from the lot tab. Set the checkbox and when a lot is generated for this partnum it will bring up a dialog box for you to enter the date.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mary Horsey
Sent: Wednesday, October 31, 2012 10:14 AM
Sincerely,
Mary Horsey
Brian.
Of Mary Horsey
Sincerely,
Mary Horsey
