Epicor - Attachment ECM - Customized folder based on the UserID
My requirement is to store the Customer documents under the following folder in ECM application.
This can be achivable in ECM workflow process.
Folder - Customer/CustomerID (CustomerID value is dynamic).
But when I attach the document directly from the Epicor,
is it possible to create the folder in ECM based on the CustomerID and store on that?
The AttachmentSvc has all of the DocStar Methods. You can make a folder and upload, but you would lose all of the builtin functions.
You can make each customer a Document Type which will make a folder, but then you have a ton of folders showing on every customer.
I am not sure what the purpose of this structure is. ECM is going to search by Keywords and CustID is set by default, so even in a single customer folder you can get one customer in a search and they only show on the customer record they are attached to in Epicor.
Thanks a lot for your suggestion.
