Epicor BAQ cannot read properties of null fix
I am having an issue when running a BAQ and pulling all the records for this BAQ. I think its just because there are too many records but I am not sure.
Here is my query:
select
    \[ShipHead\].\[ShipDate\] as \[ShipHead_ShipDate\],
    \[OrderHed\].\[SalesRepList\] as \[OrderHed_SalesRepList\],
    \[Customer\].\[Name\] as \[Customer_Name\],
    \[OrderHed\].\[ShipToNum\] as \[OrderHed_ShipToNum\],
    \[OrderHed\].\[PONum\] as \[OrderHed_PONum\],
    \[ShipDtl\].\[OrderNum\] as \[ShipDtl_OrderNum\],
    (OrderDtl.DocUnitPrice -  ( OrderDtl.Discount / NULLIF(OrderDtl.SellingQuantity, 0) )) as \[Calculated_totwdis\],
    (CASE
    WHEN CurrExRate1.CurrentRate > 0 THEN
        (totwdis)\*(1/CurrExRate1.CurrentRate)
    ELSE (totwdis)
END) as \[Calculated_Convertedtotwdis\],
    (PartTran.TranQty \* totwdis) as \[Calculated_etotwdis\],
    (CASE
        (etotwdis)\*(1/CurrExRate1.CurrentRate)
    ELSE (etotwdis)
END) as \[Calculated_Convertedetotwdis\],
    \[PartTran\].\[ExtCost\] as \[PartTran_ExtCost\],
    \[PartTran\].\[TranQty\] as \[PartTran_TranQty\],
    \[ShipDtl\].\[LineDesc\] as \[ShipDtl_LineDesc\],
    ((  ( etotwdis - PartTran.ExtCost )  / NULLIF(etotwdis, 0) )  \* 100) as \[Calculated_grossmargin\],
    ((  ( Convertedetotwdis - PartTran.ExtCost )  / NULLIF(Convertedetotwdis, 0) )  \* 100) as \[Calculated_convertedGrossMargin\],
    \[ShipDtl\].\[PartNum\] as \[ShipDtl_PartNum\],
    \[OrderDtl\].\[ProdCode\] as \[OrderDtl_ProdCode\],
    \[ShipDtl\].\[JobNum\] as \[ShipDtl_JobNum\],
    \[ShipTo\].\[City\] as \[ShipTo_City\],
    ((case when  OrderHed.UseOTS =  1  then   OrderHed.OTSCity  else  ShipTo.City end)) as \[Calculated_sCity\],
    \[ShipTo\].\[State\] as \[ShipTo_State\],
    ((case when  OrderHed.UseOTS =  1  then  OrderHed.OTSState  else  ShipTo.State end)) as \[Calculated_sState\],
    \[ShipTo\].\[Country\] as \[ShipTo_Country\],
    ((case when  OrderHed.UseOTS =  1  then  Country.Description  else  ShipTo.Country end)) as \[Calculated_sCountry\],
    \[ShipHead\].\[Invoiced\] as \[ShipHead_Invoiced\],
    \[ShipHead\].\[ReadyToInvoice\] as \[ShipHead_ReadyToInvoice\],
    \[OrderHed\].\[Date09\] as \[OrderHed_Date09\],
    \[OrderHed\].\[OrderDate\] as \[OrderHed_OrderDate\],
    \[PartPlant\].\[LeadTime\] as \[PartPlant_LeadTime\],
    \[OrderHed\].\[Company\] as \[OrderHed_Company\],
    \[SalesTer\].\[TerritoryDesc\] as \[SalesTer_TerritoryDesc\],
    \[SalesTer\].\[TerritoryID\] as \[SalesTer_TerritoryID\],
    \[SalesTer\].\[RegionCode\] as \[SalesTer_RegionCode\],
    \[OrderHed\].\[RequestDate\] as \[OrderHed_RequestDate\],
    \[CustAttr\].\[AttrCode\] as \[CustAttr_AttrCode\],
    \[PartTran\].\[TranDate\] as \[PartTran_TranDate\],
    \[OrderHed\].\[ReservePriorityCode\] as \[OrderHed_ReservePriorityCode\],
    \[OrderHed\].\[InternalSalesRep_c\] as \[OrderHed_InternalSalesRep_c\]
from Erp.ShipHead as \[ShipHead\]
inner join Erp.ShipDtl as \[ShipDtl\] on
      ShipHead.Company = ShipDtl.Company
    and  ShipHead.PackNum = ShipDtl.PackNum
left outer join Erp.OrderHed as \[OrderHed\] on
      ShipDtl.Company = OrderHed.Company
    and  ShipDtl.OrderNum = OrderHed.OrderNum
left outer join Erp.Country as \[Country\] on
      OrderHed.Company = Country.Company
    and  OrderHed.OTSCountryNum = Country.CountryNum
left outer join Erp.CurrExRate as \[CurrExRate1\] on
      OrderHed.Company = CurrExRate1.Company
    and  OrderHed.CurrencyCode = CurrExRate1.TargetCurrCode
    and ( CurrExRate1.EffectiveDate >= ALL (select Calculated_LatestExchangeRateDate from ((select
    (max(CurrExRate.EffectiveDate)) as \[Calculated_LatestExchangeRateDate\],
    \[CurrExRate\].\[SourceCurrCode\] as \[CurrExRate_SourceCurrCode\]
from Erp.Currency as \[Currency\]
inner join Erp.CurrExRate as \[CurrExRate\] on
      Currency.Company = CurrExRate.Company
group by
    \[CurrExRate\].\[SourceCurrCode\])) as SubQuery2)
and CurrExRate1.SourceCurrCode = 'Base'  )
inner join Erp.OrderDtl as \[OrderDtl\] on
      ShipDtl.Company = OrderDtl.Company
    and  ShipDtl.OrderNum = OrderDtl.OrderNum
    and  ShipDtl.OrderLine = OrderDtl.OrderLine
    and ( OrderDtl.ProdCode LIKE 'P%'
or OrderDtl.ProdCode LIKE 'C%'  )
left outer join Erp.PartTran as \[PartTran\] on
      ShipDtl.Company = PartTran.Company
    and  ShipDtl.PackNum = PartTran.PackNum
    and  ShipDtl.PackLine = PartTran.PackLine
    and  ShipDtl.Plant = PartTran.Plant
    and ( (PartTran.TranType = 'STK-CUS'
or PartTran.TranType = 'MFG-CUS' )
and PartTran.RevertStatus = 0  )
left outer join Erp.PartPlant as \[PartPlant\] on
      PartTran.Company = PartPlant.Company
    and  PartTran.PartNum = PartPlant.PartNum
    and  PartTran.Plant = PartPlant.Plant
inner join Erp.Customer as \[Customer\] on
      ShipHead.Company = Customer.Company
    and  ShipHead.CustNum = Customer.CustNum
left outer join Erp.CustAttr as \[CustAttr\] on
      Customer.Company = CustAttr.Company
    and  Customer.CustNum = CustAttr.CustNum
inner join Erp.SalesTer as \[SalesTer\] on
      Customer.Company = SalesTer.Company
    and  Customer.TerritoryID = SalesTer.TerritoryID
left outer join Erp.ShipTo as \[ShipTo\] on
      ShipHead.Company = ShipTo.Company
    and  ShipHead.ShipToNum = ShipTo.ShipToNum
    and  ShipHead.ShipToCustNum = ShipTo.CustNum
where ( ShipDtl.OrderNum > 0  )
order by ShipHead.PackNum, ShipDtl.PackLine
Normally this wouldnt be an issue but I am trying to add this to a dashboard and I am having trouble because when I am running the BAQ in app studio it is crashing the app I am working on. I want to run it without filters but I am not too sure how to get around this. All the data I have is needed by the team so any advice?
What’s the purpose of this dashboard? 2 billion+ rows is quite a lot and pretty much the maximum value you can put in a 32-bit signed integer. Any more than that is likely going to cause more problems than app studio crashing.
Just at a first glance, using PartTran like that is going to explode the amount of rows if you don’t use any grouping.
Edit:
The joins for CurrExRate and CustAttr could also be a problem.
I would put PartTran in a subquery with a filter on the table for those two TranTypes, then add that subquery to a higher lever with an inner join to the other table.
How many records would you expect to be loaded in this BAQ at one time without parameter filters.
Did you run this in the swagger help tool?
no what is the swagger help tool?
He’s talking about the REST help page (https://<host_name>/<app_server>/apps/resthelp/#/home), then running the BAQ from there.
Not sure that’ll do much, it’s likely to do the same as the Kinetic app where the browser freezes up or crashes.
Yes the Rest help page. Thanks @genoah.martinelli for the link.
It might give more details on what is coming back.
