Hi
I am new to this group and the API’s within Epicor.
I have been able to create the cash receipts entry using the CashGrpSvc Erp.BO.CashGrpSvc/CashGrps, but I am unable to post the misc line items to get or post using the API.
Any help or pointers
is much appreciated.
If you’re stuck on which exact fields to fill, perform the action once manually in the Epicor “Cash Receipt Entry” screen while running a Trace.
The trace log will show you the exact sequence of API calls and field names Epicor uses behind the scenes.
Thanks Dnyanraj_Patil for pointers but couldnt follow the steps I needed, as I am a user and system admin didnt know abt it .
After trial and errors of few API’s found that I was able to post and create mispay items using api post call ./Erp.BO.CashRecSvc/CashRecs
Hi Team
I have hit another roadblock now with the update of the GLAccount code, is not reflected even when I try to create or update using /Erp.BO.CashRecSvc/UpdateMaster. It defaults to the default GLCode. . Any pointers
Hi Team
Anyone, any pointers please, I am still stuck with this and cant seem to figure out the reason why it picks the default GL Code
Thansk in Advance
