Recently someone noticed there is a 64 bit client in the Epicor install directory, but the default shortcuts created during install use the 32 bit client. Is there a performance benefit to using the 64 bit client(e.g. give Epicor client access to more than 4GB of RAM)?
I think the general rule is use the 32 bit client by default unless there is a strong reason to use the 64bit version. We have some users using the 64 bit version as we have a customisation that uses some Solidworks dlls that are 64bit only. There was also an issue with Epicor Data Discovery and the 64 bit client. Given most (99%) people use the 32bit client all the bugs have been ironed out. not so with the 64 bit version.
Brett
