Epicor Kinetic 2022.2.8 BOM Comparisons
I am looking to do BOM comparisons within Epicor Kinetic 2022.2.8 via the Revision Compare Process. I am looking at two General Assemblies (GA’s). I would like the comparison to only look at Part changes, & quantity required changes. The current system looks at material sequence numbers as well as multiple other parameters this then highlights that there is a change even though the part, qty are identical between the two GA’s. Is there a way to allow Revision Compare to only search certain parameters?
