Epicor Kinetic Fulfillment Workbench – Add PhaseID Search Filter
Version 10.X / 202X.Y → 202X.Z
I am customizing the Epicor Kinetic Fulfillment Workbench and need some guidance on implementing a PhaseID-based search.
I want to add another textbox called PhaseID to this existing search panel.
The objective is to search and retrieve Fulfillment Workbench records based on PhaseID while retaining all the existing search functionality.
I have investigated the existing search functionality but cannot find a straightforward way to customize the standard search slide-out panel through Application Studio.
My questions:
  1. Is there a supported way to add a custom PhaseID textbox to the existing Fulfillment Workbench search panel?
  2. Can this be achieved through Ice.Lib.MetaFX.GetSearch using a Post BPM to modify the search metadata?
  3. Is it possible to pass the PhaseID value to the server-side search method through a BPM without modifying the standard BO contract?
  4. Can a BPM filter the returned records based on JobHead.PhaseID while preserving the standard Fulfillment Workbench functionality?
  5. Has anyone implemented a similar custom search filter?
i tried below with baq --< Project and Phase ID it is not working
Issues data is loding into grd of fulfilment
I’ve never found a way to edit any stock Epicor / Kinetic searches.
I’m assuming your quick-search is probably the way to go, but the grid (and the dataview/events driving it) may need to be tweaked to include your added PhaseID parameter.
Fulfillment workbench is tricky as well as there are three grids layered together.
