I added a Quick Search in Time and Expense Entry based on a BAQ to only pull in active employees where the supervisor is equal to the current logged in employee. It pulls up the correct records when searching, and allows me to select one employee from the list and pull it into the form. If I select multiple records Epicor will lock up and require a hard restart. Anyone run into this; is it a known issue?
I figured it out…it’s because I was opening the Quick Search from the Open With dialog. Works fine if I select the Quick Search from that tab in the normal search dialog.
