If you are referring to the ones asking yes/no for delete save etc...I think you need to do it by form...For example, open the Sales Order form and go to tools, options...Then choose the dialog tab which has several questions and several sub tabs, check/uncheck as needed - maybe in test system first to see results.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rick
Sent: Wednesday, November 02, 2011 1:20 PM
Subject: [Vantage] Epicor PopUp Questions
There are PopUp Questions that Epicor has, but I have the same anwser for them all the time.
Is there a way to answer these in the back round, and run the process?
Sincerely,
Rick
Sincerely,
Rick
