Epicor Portal Error... Error HRESULT E_FAIL has been returned from a
I once a day on average get this error... impersonation is enabled by default, MSDTC restart does not help... any advice on tracking down the reason I get this error that forces me to do a hard restart of the web server to get the epicor portal working?
...k: at System.Web.UI.Page.HandleError(Exception e)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at ASP.default_aspx.ProcessRequest(HttpContext context)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Error HRESULT E_FAIL has been returned from a call to a COM component.
Type:System.Runtime.InteropServices.COMException
Stack:
Server stack trace:
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
at System.EnterpriseServices.Thunk.Proxy.CoCreateObject(Type serverType, Boolean bQuerySCInfo, Boolean& bIsAnotherProcess, String& uri)
at System.EnterpriseServices.ServicedComponentProxyAttribute.CreateInstance(Type serverType)
at System.Runtime.Remoting.Activation.ActivationServices.IsCurrentContextOK(Type serverType, Object[] props, Boolean bNewObj)
at Epicor.Berlin.Hub.HubUtils.IsUserExists(String sUser)
at Epicor.Berlin.Hub.IRetriever.IsUserExists(String sUser)
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Epicor.Berlin.Hub.Retriever.IsUserExists(String sUser)
at Epicor.Berlin.Typhoon.Operations.IsUserExists(String sUser)
at Epicor.Berlin.Typhoon.Operations.get_SidAsString()
at ASP.default_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer)
at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children)
at System.Web.UI.Page.Render(HtmlTextWriter writer)
Source: System.Web
Message: Error HRESULT E_FAIL has been returned from a call to a COM component.
Stack:
Server stack trace:
Source: mscorlib
System.Web.HttpUnhandledException: Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
Server stack trace:
--- End of inner exception stack trace ---
