Hi everyone,
I want to add a pre-processing for one updateable external BAQ and I have this error.
I’m not sure the reason, as I am able to add the same customization on another updatable external BAQ using another datasource.
Server Side Exception
There is at least one compilation error.
Error Detail
Description: There is at least one compilation error.
Details:
Error CS0117: ‘Ice.Utility.Serializer’ does not contain a definition for ‘DeserializeDouble’ [QueryResultUbaqTableset.cs(511,51)]
Error CS1502: The best overloaded method match for ‘Ice.Utility.Serializer.Serialize(bool, System.IO.Stream)’ has some invalid arguments [QueryResultUbaqTableset.cs(529,13)]
Error CS1503: Argument 1: cannot convert from ‘double’ to ‘bool’ [QueryResultUbaqTableset.cs(529,34)]
Program: Epicor.Customization.dll
Method: PrepareException
Line Number: 99
Column Number: 13
Server Trace Stack: at Epicor.Customization.Standard.CustomizationCompiler.PrepareException(CompilerErrorCollection errors) in c:_Releases\ICE\3.1.400.17\source\Framework\Epicor.Customization\Standard\CustomizationCompiler.cs:line 99
at Epicor.Customization.Standard.CustomizationCompiler.Compile(BuildEnvironment input, String outputAssembly) in c:_Releases\ICE\3.1.400.17\source\Framework\Epicor.Customization\Standard\CustomizationCompiler.cs:line 29
at Epicor.Customization.Standard.CustomizationBuilder.Process(CustomizationProject project) in c:_Releases\ICE\3.1.400.17\source\Framework\Epicor.Customization\Standard\CustomizationBuilder.cs:line 78
at Ice.Services.BO.BpMethodSvc.AfterUpdate() in c:_Releases\ICE\3.1.400.17\source\Server\Services\BO\BpMethod\BpMethod.Events.cs:line 85
at Ice.Services.Trace.TablesetProfilingCollector.DoTablesetEventTrace(String tablesetName, String methodName, Action action) in c:_Releases\ICE\3.1.400.17\source\Framework\Epicor.Ice\Services\TablesetProfilingCollector.cs:line 200
at Ice.TablesetBound3.InnerUpdate(IceDataContext dataContext, TFullTableset tableset) in c:\_Releases\ICE\3.1.400.17\source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 814 at Ice.Services.BO.BpMethodSvc.Update(BpMethodTableset& ds) in c:\_Releases\ICE\3.1.400.17\source\Server\Services\BO\BpMethod\BpMethod.Designer.cs:line 835 at Ice.Services.BO.BpMethodSvcFacade.Update(BpMethodTableset& ds) in c:\_Releases\ICE\3.1.400.17\source\Server\Services\BO\BpMethod\BpMethodSvcFacade.cs:line 224 at SyncInvokeUpdate(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in c:_Releases\ICE\3.1.400.17\source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func2 func) in c:\_Releases\ICE\3.1.400.17\source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28 at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in c:\_Releases\ICE\3.1.400.17\source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23 at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc) at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet) at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result) at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result) at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result) at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously) at System.ServiceModel.Channels.SecurityChannelListener1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Ice.Proxy.BO.BpMethodImpl.Update(BpMethodDataSet ds)
at Ice.Adapters.BpMethodAdapter.OnUpdate()
at Ice.Lib.Framework.EpiBaseAdapter.Update()
at Ice.UI.App.BpMethodEntry.Transactions.MainTransactionBase.adapterUpdate()
