Epicor Trace Differ
Hi Experts,
I have loaded the Epicor Trace Differ by Jose Gomez.
I get the following error when I do a compare. I have installed and run as Admin and have .net 4.8 installed, on windows 10 pro.
Any suggestions to fix this issue would be great.
Error message is below.
Thanks Steve
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at EpicorTraceDiffer.frmTraceDiffer.btnCompare_Click(Object sender, EventArgs e) in C:\Users\jose\source\repos\EpicorTraceDiffer\EpicorTraceDiffer\frmMain.cs:line 117
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4515.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EpicorTraceDiffer
Assembly Version: 1.0.0.7
Win32 Version: 1.0.0.7
CodeBase: file:///C:/Program%20Files%20(x86)/Jose%20and%20Josh%20Do%20Dev/Epicor%20Trace%20Differ/EpicorTraceDiffer.exe
Win32 Version: 4.8.4550.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.4536.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Win32 Version: 4.8.4579.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Win32 Version: 4.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
ScintillaNET
Assembly Version: 3.6.3.0
Win32 Version: 3.6.3.0
CodeBase: file:///C:/Program%20Files%20(x86)/Jose%20and%20Josh%20Do%20Dev/Epicor%20Trace%20Differ/ScintillaNET.DLL
Menees.Diffs.Controls
Assembly Version: 4.0.2.0
Win32 Version: 4.0.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Jose%20and%20Josh%20Do%20Dev/Epicor%20Trace%20Differ/Menees.Diffs.Controls.DLL
Menees.Windows.Forms
Assembly Version: 4.5.5691.32059
Win32 Version: 4.5.5691.32059
CodeBase: file:///C:/Program%20Files%20(x86)/Jose%20and%20Josh%20Do%20Dev/Epicor%20Trace%20Differ/Menees.Windows.Forms.DLL
Menees.Diffs
CodeBase: file:///C:/Program%20Files%20(x86)/Jose%20and%20Josh%20Do%20Dev/Epicor%20Trace%20Differ/Menees.Diffs.DLL
AutoUpdater.NET
Assembly Version: 1.5.4.0
Win32 Version: 1.5.4.0
CodeBase: file:///C:/Program%20Files%20(x86)/Jose%20and%20Josh%20Do%20Dev/Epicor%20Trace%20Differ/AutoUpdater.NET.DLL
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
