I will be on vacation and out of the office from Monday March 19th and returning Thursday March 29th.  All emails are being forwarded to Dan Sutherby during this period.  If it is urgent he can be reached at 508-970-0099x120.
            Looking to create a customization for the CheckListDtl form where if Checkbox01 is true an EpiShape is green else the EpiShape is red.
This has to be fairly straight forward, but not sure where to start.
Heres a snippet from my job tracker....
Sub Status_Head()
Dim edvJobHead As EpiDataView = CType(oTrans.EpiDataViews("JobHead"),EpiDataView)
Dim shpDMRAlertH as EpiShape
shpDMRAlertH = CType(csm.GetNativeControlReference("c1544ca8-82f8-4ec4-9602-67064b5e679a"),EpiShape)
try
if edvJobHead.dataView(edvJobHead.Row)("CheckBox02") = True Then
'messagebox.show("check on")
shpDMRAlertH.Enabled = True
shpDMRAlertH.Status = StatusTypes.stop
shpDMRAlertH.EnabledCaption = "DMR Present"
Else
if edvJobHead.dataView(edvJobHead.Row)("CheckBox02") = False Then
'messagebox.show("check off")
shpDMRAlertH.Enabled = False
End If
End If
Catch ex as Exception
'shpDMRAlert.Visible = false
End Try
End Sub
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Anon
Sent: Saturday, February 04, 2012 4:07 PM
Subject: [Vantage] EpiShape Changes
            Sub Status_Head()
try
Else
End If
End If
End Try
End Sub
Rob Bucek
FAX: (715)284-4084
shpDMRAlertH =
EpiShape)
Is that line the reason why I can't just take the name of a native control
and modify properties. Example being say I have the epiOrderNum field, a
native control and the txtMyCustomControl field a custom control.
I can't seem to do epiOrderNum.Text = "kjasdfjs", but I can do
txtMyCustomControl.Text = "ajskfjks" for some reason within the same block
of code. Didn't understand it. Do I have to get those native controls
using the keys?
Also for the coloring the piece I was missing was 'shpDMRAlertH.Status =
StatusTypes.XXXXX'.
Thank you very much.
Joshua Giese
Chief Technical Officer
920.437.6400 Ext. 337
*Do not follow where the path may lead. Go instead where there is no path
and leave a trail - Harold R. McAlindon*
Rob Bucek
Sent: Monday, February 06, 2012 8:30 AM
Subject: RE: [Vantage] EpiShape Changes
Sub Status_Head()
shpDMRAlertH =
EpiShape)
try
Else
End If
End If
End Try
End Sub
Rob Bucek
FAX: (715)284-4084
<mailto:1.234354861%40web65412.mail.ac4.yahoo.com> ]<http://www.dsmfg.com/>
Behalf Of Anon
EpiShape)
using the keys?
StatusTypes.XXXXX'.
Joshua Giese
Rob Bucek
Sub Status_Head()
shpDMRAlertH =
EpiShape)
try
Else
End If
End If
End Try
End Sub
Rob Bucek
FAX: (715)284-4084
Behalf Of Anon
StatusTypes.Warning
StatusTypes.Global
StatusTypes.OK
StatusTypes.Stop
ex.
shpEpiCustom1.Status = StatusTypes.Warning
As for setting the status types based on the value of a given field or control, it shouldn't have any bearing on whether or not it is a native or custom control.
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Giese
Sent: Monday, February 06, 2012 8:36 AM
shpDMRAlertH =
EpiShape)
using the keys?
StatusTypes.XXXXX'.
Joshua Giese
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Rob Bucek
Sub Status_Head()
shpDMRAlertH =
EpiShape)
try
Else
End If
End If
End Try
End Sub
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...<mailto:1.234354861%40web65412.mail.ac4.yahoo.com>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of Anon
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
            StatusTypes.Global
StatusTypes.OK
StatusTypes.Stop
ex.
Rob Bucek
FAX: (715)284-4084
shpDMRAlertH =
EpiShape)
using the keys?
StatusTypes.XXXXX'.
Joshua Giese
Rob Bucek
Sub Status_Head()
shpDMRAlertH =
EpiShape)
try
Else
End If
End If
End Try
End Sub
Rob Bucek
FAX: (715)284-4084
Behalf Of Anon
Serious bug in my last post with complete code, deleted that and re-posting.
Private Sub Dtl_AfterRowChange(ByVal args As EpiRowChangedArgs)
UpdateApprovedShape()
End Sub
Private Sub Dtl_DataView_ListChanged(ByVal sender As Object, ByVal args As ListChangedEventArgs)
End Sub
Private Sub UpdateApprovedShape()
' Create/Set Function level vars
Dim shpApproved as EpiShape = CType(csm.GetNativeControlReference("1be4b636-4a3d-4af9-b5cf-d764445f9de6"),EpiShape)
Dim edvDtl As EpiDataView = CType(oTrans.EpiDataViews("Dtl"),EpiDataView)
' Try to set approval EpiShape
Try
If edvDtl.dataView(edvDtl.Row)("CheckBox01") Then
shpApproved.Visible = true
shpApproved.Status = StatusTypes.ok
shpApproved.EnabledCaption = "Approved"
Else
shpApproved.Status = StatusTypes.stop
shpApproved.EnabledCaption = "Not Approved"
End If
Catch ex As Exception
' EpiMessageBox.Show("Unable to get Approved Status")
End Try
End Sub
End Sub
End Sub
Try
Else
End If
End Try
End Sub
--- In vantage@yahoogroups.com, Rob Bucek <rbucek@...> wrote:
> StatusTypes.Warning
> StatusTypes.Global
> StatusTypes.OK
> StatusTypes.Stop
> ex.
> Rob Bucek
> FAX: (715)284-4084
> shpDMRAlertH =
> EpiShape)
> using the keys?
> StatusTypes.XXXXX'.
> Joshua Giese
> Rob Bucek
> Sub Status_Head()
> shpDMRAlertH =
> EpiShape)
> try
> Else
> End If
> End If
> End Try
> End Sub
> Rob Bucek
> FAX: (715)284-4084
> Behalf Of Anon
Mr. Bucek which version of Vantage are you using? I can't seem to get mine to work and Epicor Support said it is because of a "limitation in Vantage" My goal is to tie the EpiShape to POHeader.VoidOrder
thanks
            thanks
> Sub Status_Head()
> try
> Else
> End If
> End If
> End Try
> End Sub
> Rob Bucek
> FAX: (715)284-4084
I'm on 8.03.409<tel:803409>c
Sent from my Verizon Wireless Droid
-----Original message-----
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Fri, Mar 16, 2012 22:50:30 GMT+00:00
Subject: [Vantage] Re: EpiShape Changes
thanks
thanks
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Rob Bucek <rbucek@...> wrote:
> Sub Status_Head()
> try
> Else
> End If
> End If
> End Try
> End Sub
> Rob Bucek
> FAX: (715)284-4084
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Anon
