EpiUltraGrid displays only one record at a time
Hello,
A new “List” sheet was added to Part Maintenance, and an EpiUltraGrid was created for the Part table, with only a few columns set to be viewed.
The new EpiUltraGrid displays only one record at a time although several are selected for display in Part Maintenance.
Is there something I’m missing in order to view all part records selected in the List view?
Thanks for any suggestions,
Karen
Most forms will only show one record at a time. However, they can show multiple records related to the parent record that the form currently has selected.
Take the Order Entry form for example. I can search and load several order numbers, but only one order is on the form at a time. Since Order lines relate to Order numbers, the form can show multiple OrderDtl records - but only those for the OrderHed selected.
If you want to view multiple Part records in a single form, you should make a dashboard. If you want to be able to edit the fields displayed, it would need to be an updatable dashboard.
Hi Calvin,
Thanks for your suggestions on this. I suspected that what you described was the case but because I’ve seen data managed in a “header-list” fashion in other screens (i.e. security group maintenance for example), I thought maybe it could be done in the Part Entry screen too.
Karen
