In that same vein. Check the schools in your state and see if they have developed anything (good as an ongoing eaching project & good cheap support to help in state businesses).
--- Original Message ---
Sent:Wed 8/11/10 3:19 pm
To:<vantage@yahoogroups.com>
Subj:RE: [Vantage] Re:ERP Alternatives
Good points, Jeff.
Another option not yet mentioned is open source (free) ERP.
http://www.openbravo.com/
https://www.jfire.org/
And, frankly, homegrown systems aren't so bad these days especially with
the out-of-box tools such as SQL Server Reporting Services and simple
ASP generated pages.
Of Jeff Lewis
Sent: Wednesday, August 11, 2010 12:42 PM
Subject: RE: [Vantage] Re:ERP Alternatives
There is(was) another option.
We licensed the source code for Vantage back in 96'. Rarely used support
because the source code is right in front of us. (We paid support like a
good customer and received upgrades.) I have watched users suffer for
years on this forum because they don't have access to the code. Truth be
told most bugs are silly things like choosing the wrong field to read
from or not setting a variable. A lot of these bugs are ten minute
fixes, but if not addressed could make a module unusable or at worst
propagate garbage data throughout the database. There are also poorly
written modules (for us) but I digress.
Well the Epicor management decided to withhold the Business Object and
Database Trigger Code (4GL code) when they opened up the user interface
customization to the masses(.NET). They claim users don't need the
source code - but the business logic is the logic of your business.
Without it the logic is hidden in a black-box which is exceedingly
difficult to troubleshoot. So you have to write more code on top of
faulty code to try and get the behavior you need. An untenable
situation.
If you ever had the veil lifted by having access to the source you would
never go back.
Jeff Lewis
Director of Engineering/IT
Behalf Of robertb_versa@... <mailto:robertb_versa%40yahoo.com>
Sent: Wednesday, August 11, 2010 10:09 AM
Subject: Re: [Vantage] Re:ERP Alternatives
Dale hit the nail on the head: It's about the quality of support over
the expected life of use - weighed against the annual cost for it. That
cost will eventually meet exceed the initial software cost - so make
sure you believe you'll get the value you'll pay for.
Don't just focus on initial cost (or the lowest common denominator
features today's bland, slow (but scaleable) systems have relative to a
decade ago).
Also: Know when to cut your losses (and learn from them) if you goof.
Don't hold the business back for the next decade by being tethered to
the wrong software & support.
Lastly: Do you really need ERP? Are your people and processes strong &
tight enough to 'feed it' (so you don't suffer GIGO) - and are you
willing to adapt processes to bend towards what your system needs fed?
Good points, Jeff.
Of Jeff Lewis
situation.
never go back.
Jeff Lewis
decade ago).
