Chan213419
(Jeremy Chance)
October 30, 2025, 5:52pm
21
I can’t share it directly, though I’d love to, but here’s all the info you’d need to build it:
Assembly:
Service:
Params:
Function Code:
CallService<DynamicQuerySvcContract>(dqSvc =>
Ice.Tablesets.QueryExecutionTableset QEts = dqSvc.GetQueryExecutionParametersByID("JobGrid");
QEts.ExecutionParameter.Clear();
var payload = new {
JobsList = this.pJobsList
var JobsList = payload.JobsList.Split(',');
foreach (var job in JobsList)
QEts.ExecutionParameter.Add(new ExecutionParameterRow
ParameterID = "JobNum",
ParameterValue = job.Trim().ToString()
DataSet qeDS = dqSvc.ExecuteByID("JobGrid", QEts);
if (qeDS.Tables[0].Rows.Count>0)
this.oDs = qeDS;
I hope this helps.
Chan213419
(Jeremy Chance)
October 30, 2025, 5:59pm
22
Maybe if you choose ‘specified constant list’ and just left it empty? Too late for me to try, but worth a shot.
jbooker
(Josh Booker)
October 30, 2025, 6:57pm
23
Yeah either that or I’m thinking of passing pure client-side Where clauses which I know for sure does indeed work (aside from a couple caveats already mensioned). Distinction being the IN() criteria is not modeled in the BAQ designer.
like:
jbooker:
"ExecutionSetting": [
"Name": "PageSize",
"Value": 100
"Name": "PageNum",
"Value": 1
"Name": "NeedTotal",
"Value": false
"Name": "Select",
"Value": "[JobHead_JobNum]"
"Name": "Where",
"Value": "JobNum IN(?{TransView.Jobs})"
"ExecutionParameter": [
"IsEmpty": true,
"ParameterID": "JobNum",
"ParameterValue": "",
"ValueType": "nvarchar"
Chan213419
(Jeremy Chance)
October 30, 2025, 8:11pm
24
Oh, I see what you’re saying now! Next time I come across this challenge, I’ll be sure to come back here. That’s way easier!
jbooker
(Josh Booker)
November 2, 2025, 11:20pm
26
FWIW, the BAQ Options > Where: IN() method does seems to work well.
using this syntax:
Job_JobNum IN (?{TransView.JobsSQL})
see:
PSS- I got the grid.ViewOptions > BAQ Options > WHERE expression to work for IN() clause
using this technique with this syntax
Part_PartNum IN (?{TransView.PartsSQL})
So now it works for a Context Menu ValueIn and a multi-select searchResult with mutli-paste using SearchChipSelector component:
[ContextMenu-SearchChip]
ridgea
(Alex Ridge)
November 12, 2025, 3:59pm
27
Nice - I used a slight different approach:
Made the BAQ updateable
Added a Pre-processing on the Get List
Then used the following code to split the string delimeted list out
