Hi
Attempting to create a GL Journal via REST and the Erp.BO.GLJournalEntrySvc/GLJournalEntries
I think I have most of the fields correct but I’m seeing a “REST API Exception” with a “Group references invalid” error message as a response. Looks like part of GLJrnHEad but apart from GroupID I can’t see anything that looks like a Group reference
I’ve stripped out everything that I think is superfluous to minimum requirements but then I can’t find anything that lists required fields (the API documentation is vague on what fields do)
And yes I am aware that this journal is unbalanced. I’m simply trying to a journal loaded via REST as a proof of concept.
{'AllowChgAfterPrint': False,
'AllowUnbalancedEntries': True,
'BookID': 'MAIN',
'CommentText': 'CommentText - A string',
'Company': 'xxxxx',
'CurrencyCode': 'AUD',
'Description': 'The General Journal Description',
'DispTotCredit': 1100.0,
'DispTotDebit': 1100.0,
'EnteredBy': 'xxxx-SBenson',
'FiscalPeriod': 9,
'FiscalYear': 2023,
'GLJrnDtlMnls': [{'BookID': 'MAIN',
'CommentText': 'Another Comment Line',
'Company': 'xxxx',
'CreditAmount': 0,
'DebitAmount': 0,
'Description': 'Journal Line 1',
'FiscalPeriod': 9,
'FiscalYear': 2023,
'GLAccount': '52020|1001',
'JEDate': '2023-03-23T11:48:26.592442+10:00',
'PostedBy': 'xxxx-SBenson',
'TransAmt': 1000}],
'GroupID': 'GJ2303SB',
'JournalCode': 'MJ',
'TotCredit': 1100.0,
'TotDebit': 1100.0}]
While I am would like a solution for this what I also want to learn is how to go about fixing this myself.
