Error 599
Thanks Ted... can you define how to do #3 on your list or point me to a
reference for this please?
Sent: Tuesday, December 18, 2001 10:02 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Error 599
599 is returned due to invalid parameters passed to the database logon.
There are many causes to this. Here are some of the things that I've had to
do to get rid of the 599 error.
1. Unregocx.bat and vcopydll.exe
2. User permissions on the WINNT\CRYSTAL (if it exists) (NT/2000/XP
Only)
3. Create a compiled report and install Crystal run-time DLL's on
system (this works great!)
4. Create System DSN instead of User or File DSN
5. Delete DSN and recreate
6. Convert to Merant 3.6 IVPRO ODBC driver (recommended as last resort)
If you have a version of Crystal 8 lying around, then I would recommend
creating the compiled report. I've read where you can create compiled
reports in 8.5 with the 8 download, but I haven't tried this yet.
Hope this helps,
Ted Kitch
Misha1, LTD.
866-464-7421
Sent: Tuesday, December 18, 2001 9:46 AM
There was a thread going on this a few weeks back. I had the problem as
well and haven't found a solution yet. My problem happened because I added
a field using ODBC. The formula problem to which Epicor alluded is only
applicable if the field is a calculation, at least as far as I can tell. I
tried their solution and it didn't help (my field isn't a formula). We also
tried their solution for unregistering and re-registering ocx files and that
didn't help. Check the archives on Yahoo Groups and you can see what other
people have tried. I don't think anyone has nailed this one yet. Am I
right?
Jon Hellebuyck
Stremel Manufacturing
Sent: Tuesday, December 18, 2001 9:35 AM
Subject: [Vantage] Error 599
I have major problems with this issue. I have a packing slip
modified by crystal to add one field. I get 599 errors when trying
to print this. Epicor stated that this is related to the type of
formula. They are not able to help me rectify this. Futhermore,
there is one workstation (98SE) printin this pack slip just fine but
I can not get any other to print it. Any suggestions?
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=214563.1778827.3296761.1261774/D=egroupweb/S=17050071
83:HM/A=867009/R=0/*http://www.crystalvoicelive.com/whatFamily.asp?Affiliate
Id=00120002>
<http://us.adserver.yahoo.com/l?M=214563.1778827.3296761.1261774/D=egroupmai
l/S=1705007183:HM/A=867009/rand=676337755>
<http://docs.yahoo.com/info/terms/> Terms of Service.
I have modified my Crystal Quote form with some tables via ODBC. When I try
to print preview the form in Vantage I get the following error: Error 599.
Does anyone have any idea what is going on?
If this matters, I am trying to do this on my Citrix server.
Thank you,
Ryan Larkin
Solid Comfort, Inc.
Ryan,
Running Vantage 4.00.904, I have had the "Error 599 :ok", followed by "Error,
Could not load DLL procedure crpe32.dll.(3258) :ok". Vantage tech support
has a document on this they can email you. For Win 95/98 workstations, you
might want to try copying the V:\progress\bin\prosql32.dll file (from the
server) to the c:\windows\system folder (overwritre old prosql32.dll ) on the
workstation where the error occurred. Reboot workstation, and see if it
works. Otherwise you will need to unregister the .ocx files, this procedure
is in the tech support doc.
Scott
right?
Jon Hellebuyck
Only)
Hope this helps,
Ted Kitch
Misha1, LTD.
866-464-7421
right?
Jon Hellebuyck
Id=00120002>
<<<< I've read where you can create compiled
reports in 8.5 with the 8 download, but I haven't tried this yet. >>>>>>
By this do you mean distributed reports? I tried for a long time to get the
8.0 download to work with 8.5 and it would never show up as a tool bar menu
option. I ended up going back to 8.0 (with lots of .DLL headaches). Sort
of like 8.5 was set to ignore it. If you can point to where you read this I
would appreciate it.
-Todd Caughey
Only)
Hope this helps,
Ted Kitch
Misha1, LTD.
866-464-7421
right?
Jon Hellebuyck
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
<http://www.crystalvoicelive.com/whatFamily.asp?Affiliate>
Id=00120002>
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Terms of Service.
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1711356.3237013.1261774/D=egroupweb/S=17050071
83:HM/A=847665/R=0/*http://ads.x10.com/?bHlhaG9vbW9uc3RlcjcuZGF0=1008691185%
3eM=215002.1711356.3237013.1261774/D=egroupweb/S=1705007183:HM/A=847665/R=1>
<http://us.adserver.yahoo.com/l?M=215002.1711356.3237013.1261774/D=egroupmai
l/S=1705007183:HM/A=847665/rand=448279115>
See my email on ERROR ON SINGLE SERVER (SOLVED, I think). Check the
configuration of your ODBC drivers
Shirley H. Graver
(End User)
Systems Administrator
Rubber Associates Inc.
Sent: Tuesday, December 18, 2001 11:02 AM
Only)
Hope this helps,
Ted Kitch
Misha1, LTD.
866-464-7421
right?
Jon Hellebuyck
< http://groups.yahoo.com/group/vantage/files/.>
< http://groups.yahoo.com/group/vantage/messages>
< http://groups.yahoo.com/group/vantage/links>
Id=00120002>
< http://docs.yahoo.com/info/terms/> Terms of Service.
ADVERTISEMENT
