Have you tried disconnecting these users with proshut? One of the options is to
disconnect a user, and will give you a list of connected users.
Proshut is a "low-Level" utility that you run from the command prompt. It should
be in $DLC/bin, where $DLC is where you installed Progress.
HTH.
jason.gippner@... wrote:
William E. Colls Tel 613 591 0079
PROComputer Systems Fax 613 591 3924
67 Willow Glen Dr www.procomsys.com
Kanata Ontario Canada PEG Member 1998051404
Specialists in Progress Software development since 1985
HTH.
> Late last week we experienced a power loss during a snow storm and our battery--
> back up did not keep the Vantage server running. As a result we have two
> employees that I cannot remove from Vantage. When I try to clock them out
> through data collection, I receive the following error:
> Lock table overflow, increase -L on server (915). Does anyone know what this
> error message means?
> Thank you,
> Jason Gippner
> APW/Wright Line
> Grass Valley, CA
> To unsubscribe from this group, send an email to:
> vantage-unsubscribe@egroups.com
