Sandy
What version of Vantage are you on and what version of Crystal are
you using?
I'm on Vantage 4.0 and have to use Crytal 7.0.
If you are on 5.2 or later Crystal 8.5 will work.
Also from the Crytal Desions knowledge base
Error 997 and error 998 occurs on client machine with PEOpenPrintJob
The information in the article refers to:
Seagate Crystal Reports 7
Applies to:
Reported version only
Print Engine (API) calls
Error 997 and 998
Graphing
Synopsis
A Microsoft Visual Basic application, using Crystal Print Engine
(API) calls, produces error 997 or error 998 when run on a client
machine. This error occurs immediately after a report is called in
the application.
Tracing the code reveals that the error occurs at the start of
PEOpenPrintJob.
The report contains several charts/graphs..
Solution
The application is missing Sscsdk32.dll. Deploying this DLL to the
client machine solves the problem.
Sscsdk32.dll is the Crystal Reports charting DLL.
HTH
you using?
Applies to:
Error 997 and 998
Graphing
Synopsis
the application.
PEOpenPrintJob.
Solution
HTH
> I changed the crystal forms that we use and inserted our new logo.
> Now I
> have two pc's that get an error 998 when they try to print any of the
> forms
> (invoices, quotes, etc). It originally said that it couldn't find
> CRPE32.DLL and I copied this to the two pc's but it still gives me
> the error
> 998. No one else has the problem. One pc is W98 and one is W2000.
> Also, is there a place you can look up what error messages mean?
> Thanks!
> Sandy Morse
> BVR Technologies Company
