Got an error I’ve never seen before. On launching the client, I got:
Details
Application Error
Exception caught in: System
Error Detail
Message: The system cannot find the path specified
Program: System.dll
Method: CreateDirectory
Client Stack Trace
at Microsoft.Win32.NativeMethods.CreateDirectory(String path, SafeLocalMemHandle acl)
at System.CodeDom.Compiler.TempFileCollection.CreateTempDirectoryWithAce(String directory, String identity)
at System.CodeDom.Compiler.TempFileCollection.GetTempFileName(String tempDir)
at System.CodeDom.Compiler.TempFileCollection.EnsureTempNameCreated()
at System.CodeDom.Compiler.TempFileCollection.AddExtension(String fileExtension, Boolean keepFile)
at System.CodeDom.Compiler.TempFileCollection.AddExtension(String fileExtension)
at System.CodeDom.Compiler.CodeCompiler.FromSourceBatch(CompilerParameters options, String[] sources)
at System.CodeDom.Compiler.CodeCompiler.System.CodeDom.Compiler.ICodeCompiler.CompileAssemblyFromSourceBatch(CompilerParameters options, String[] sources)
at System.CodeDom.Compiler.CodeDomProvider.CompileAssemblyFromSource(CompilerParameters options, String[] sources)
at Ice.Lib.Customization.CustomScriptManager.BuildCustomAssembly(String filePath, CodeDomProvider codeProvider, CompilerParameters parameters, String source, String& sourceFileName)
at Ice.Lib.Customization.CustomScriptManager.CompileCustomScript(Boolean loading)
This appears after the main window appears, and with “Downloading from Database” is in the little status window.
Clicking OK clears the message, but the error pops up when opening other forms.
After closing the client and relaunching it, the error still appears.
Anything to be concerned about?
