I am getting the following error while running reports in one of our test environments which i have just migrated Live to -
Program Ice.Services.Lib.RunTask when executing task 13391 raised an unexpected exception with the following message: RunTask:
System.Data.Entity.Core.EntityCommandExecutionException: An error occurred while executing the command definition. See the inner exception for details.
---> Microsoft.Data.SqlClient.SqlException (0x80131904): Invalid column name 'CustXRefPartNum_c'.
Invalid column name 'CustXRefCustID_c'.
Invalid column name 'Customer_c'.
at Microsoft.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at Microsoft.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at Microsoft.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, SqlCommand command, Boolean callerHasConnectionLock, Boolean asyncClose)
at Microsoft.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at Microsoft.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at Microsoft.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
at Microsoft.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean isAsync, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at Microsoft.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry, String method)
at Microsoft.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.Entity.Infrastructure.Interception.InternalDispatcher`1.Dispatch[TTarget,TInterceptionContext,TResult](TTarget target, Func`3 operation, TInterceptionContext interceptionContext, Action`3 executing, Action`3 executed)
at System.Data.Entity.Infrastructure.Interception.DbCommandDispatcher.Reader(DbCommand command, DbCommandInterceptionContext interceptionContext)
at System.Data.Entity.Core.EntityClient.Internal.EntityCommandDefinition.ExecuteStoreCommands(EntityCommand entityCommand, CommandBehavior behavior)
ClientConnectionId:b41872f1-d0be-4590-aa19-65f8a6576d03
Error Number:207,State:1,Class:16
--- End of inner exception stack trace ---
at System.Data.Entity.Core.Objects.Internal.ObjectQueryExecutionPlan.Execute[TResultType](ObjectContext context, ObjectParameterCollection parameterValues)
at System.Data.Entity.Core.Objects.ObjectContext.ExecuteInTransaction[T](Func`1 func, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction, Boolean releaseConnectionOnSuccess)
at System.Data.Entity.Core.Objects.ObjectQuery`1.<>c__DisplayClass41_0.<GetResults>b__0()
at System.Data.Entity.Core.Objects.ObjectQuery`1.GetResults(Nullable`1 forMergeOption)
at System.Data.Entity.Internal.LazyEnumerator`1.MoveNext()
at System.Linq.Enumerable.TryGetFirst[TSource](IEnumerable`1 source, Boolean& found)
at System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable`1 source)
at System.Data.Entity.Core.Objects.CompiledQuery.ExecuteQuery[TResult](ObjectContext context, Object[] parameterValues)
at Epicor.Data.DBExpressionCompiler.GetResult[TDataContext,TQuery,TResult](Func`3 executeQuery, Cache cacheSetting, TDataContext dataContext, TQuery query) in C:\_releases\ICE\ICE5.1.100.6\Source\Server\Framework\Epicor.System\Data\EntityFramework\DBExpressionCompiler.cs:line 441
at Epicor.Data.DBExpressionCompiler.InvokeSingle[TDataContext,TQuery,TResult](Operation operation, Expression expression, Cache currentCacheSetting, Boolean cacheQuery, TDataContext dataContext, String callingMethod, Func`2 getDataCacheKey, Func`2 compileQuery, Func`3 executeQuery)
at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass55_0`4.<Compile>b__0(TDataContext dataContext, TArg1 arg1, TArg2 arg2)
at Erp.Internal.PM.POForm.FindFirstPart(String company, String partNum) in C:\_releases\ERP\ERP12.1.100.0\Source\Server\Internal\PM\POForm\POForm.Queries.cs:line 242
at Erp.Internal.PM.POForm.doPODetailCalculations() in C:\_releases\ERP\ERP12.1.100.0\Source\Server\Internal\PM\POForm\POForm.cs:line 631
at Erp.Internal.PM.POForm.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_releases\ERP\ERP12.1.100.0\Source\Server\Internal\PM\POForm\POForm.cs:line 410
at Ice.Core.TaskBase`1.StartProcess(Int64 instanceTaskNum, String outputFileName) in C:\_releases\ICE\ICE5.1.100.6\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskBase.cs:line 53
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:\_releases\ICE\ICE5.1.100.6\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 114
at Ice.Hosting.TaskCaller.ExecuteTask() in C:\_releases\ICE\ICE5.1.100.6\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 62
at Ice.Hosting.TaskCaller.ExecuteTask(IceDataContext dataContext, Boolean suppressTransaction) in C:\_releases\ICE\ICE5.1.100.6\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 42
at Ice.Services.Lib.RunTaskSvc.<>c__DisplayClass19_2.<InnerRunTask>b__1() in C:\_releases\ICE\ICE5.1.100.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 352
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:\_releases\ICE\ICE5.1.100.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 57
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:\_releases\ICE\ICE5.1.100.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 349
It seems to be moaning about 3 custom fields but those fields do not exist in any of our environments or reports ![]()
