Error When Saving BAQ Report Designer
Get the following error when trying to save a BAQ report using BAQ report designer.
No HTTP resource was found that matches the request URI ‘http://dts-kineticsql/Reports/api/v2.0/CatalogItems(path=‘/TestEnvir/reports/CustomReports/BAQReport’)/Content/$value
The URL works all the way down till /Content/$value. If I load the GUID into (Path=) it downloads the report.
SSRS portal is up, and folder hierarchy is correct. The issue is happening on both our 25.1.12 app, and 25.2.8
Its not really clear what you are doing. If you start at the beginning of your process and explain what steps you have done and at what point you are getting the error somebody can probably help. For example, is this a new baq report and this is the first time you are trying to save the record? Or this is an existing report and you are trying to upload a revised rdl? Or something else?
This specific issue is tied with saving a new report. When we go to save, the error is reporting that the path cannot be found (404). If we call the path from the application server via filepath in the URL, it gives a 404. If we call the path with GUID instead of filepath in the URL it works.
We are getting this same error in 2025.2.12
Easy way to Repo
Open Report Style → Actions → Copy Report → give it a new name… Save
Can others in 2025.2.X Test it for me
@jgiese.wci confirms his same issue, can some of the Cloudy folks try it?
Tested it in Kinetic UX same issue.
I can try too, I will do that Jose.
when you say give it a new name, are you saying change the folder name?
Does this need to be a BAQ report style or just any report style?
I see you were using aged payables
@josecgomez, I copied the BOM cost report and changed the report folder name and saved… no issue: 2025.2.14
As an update to this issue, currently working with Epicor on a support case. The issue with this is known. The fix was recommended to be catching up all SQL and SSRS Cumulative Updates. Once I am able to test this, will update thread.
@josecgomez , is that what you were asking me to test?
Yeah it worked for you… interesting it hasn’t worked for the on prem folks. There must be some magic checkbox somewhere.
Wish I could test that for you, the on prem is still on 2024.2.
No issue copying report styles for me in 2025.2.10 (LIVE), or 2025.2.14 (PILOT)
That being said… I did NOT give it any new names during the copy process. It prompts that you can change the folder… but typically the report styles all live together. I don’t want the file structure to change.
I let it create the new style as “Standard - SSRS - Copy”… then I’ll rename it in the details form afterwards.
Sorry Jose, not experiencing the same issue you appear to be having.
We upgraded from Kinetic 2022 to 2025.2.12.
After upgrade, we faced exactly the same error in BAQ Report Designer & Report Style too.
After long hours of analysis and troubleshooting, the FIX in our case was:
Upgrading SSRS 2019 to SSRS 2022.
Technically, the below HTTP request is not accepted in SSRS 2019:
http://servername/Reports/api/v2.0/CatalogItems(path=‘/E10Prod/reports/CustomReports/BAQReport’)/Content/$value
In SSRS 2022, it worked perfectly!
Thanks for sharing @IbrahimAbbas!
