Using Job Wizard to create a job we get this error: (I am assuming this has something to do with the customizations??)
An error occurred while updating the entries. See the inner exception for details.
Error Detail
Description: An error occurred while updating the entries. See the inner exception for details.
Program: Erp.Internal.MR.CPMethod.dll
Method: _CPMethod
Line Number: 1363
Column Number: 21
Server Trace Stack: at Erp.Internal.MR.CPMethod._CPMethod(Guid TargetAsm_Rowid, String Source_Part, String Source_Rev, String Source_AltMethod, Object hProcessInfo, Boolean msg_prompt, Boolean Use_Source_AltMethod, Boolean fromCpMethod, Boolean doRoughCutSched, Boolean& crossPlant, Nullable1& useDate, String& useJob, String& useRev, Int32& cfgPhantomCount, List1& opTgtJobRows, Int32 structID) in c:_Releases\ERP\UD10.1.400.37\Source\Server\Internal\MR\CPMethod\CPMethod.cs:line 1363
at Erp.Internal.MR.CPMethod._CPMethod(Guid TargetAsm_Rowid, String Source_Part, String Source_Rev, String Source_AltMethod, Object hProcessInfo, Boolean msg_prompt, Boolean Use_Source_AltMethod, Boolean fromCpMethod, Boolean doRoughCutSched, Boolean& crossPlant, Nullable1& useDate, String& useJob, String& useRev, List1& opTgtJobRows) in c:_Releases\ERP\UD10.1.400.37\Source\Server\Internal\MR\CPMethod\CPMethod.cs:line 854
at Erp.Services.BO.OrderJobWizSvc.getDetails(Boolean& errorOccurred) in c:_Releases\ERP\UD10.1.400.37\Source\Server\Services\BO\OrderJobWiz\OrderJobWiz.cs:line 2282
at Erp.Services.BO.OrderJobWizSvc.processJWOrderDtls(String& OP_ErrorMsgs) in c:_Releases\ERP\UD10.1.400.37\Source\Server\Services\BO\OrderJobWiz\OrderJobWiz.cs:line 2756
at Erp.Services.BO.OrderJobWizSvc.CreateJobs(OrderJobWizTableset& ds, String& pErrorMessages) in c:_Releases\ERP\UD10.1.400.37\Source\Server\Services\BO\OrderJobWiz\OrderJobWiz.cs:line 1387
at Epicor.Customization.Bpm.MethodCustomizationBase23.RunDirectives(TParam parameters) in c:\_Releases\ICE\3.1.400.37\Source\Server\Internal\Lib\Epicor.Customization.BPM\MethodCustomizationBase2.cs:line 218 at Epicor.Customization.Bpm.CustomizationBase23.Execute(TParam parameters) in c:_Releases\ICE\3.1.400.37\Source\Server\Internal\Lib\Epicor.Customization.BPM\CustomizationBase2.cs:line 77
at Epicor.Customization.Bpm.BOCC2F238A1C9E4D85B08E5A44ECF7E6B7.OrderJobWizSvcCustomization.CreateJobs(OrderJobWizTableset& ds, String& pErrorMessages)
at Erp.Services.BO.OrderJobWizSvcFacade.CreateJobs(OrderJobWizTableset& ds, String& pErrorMessages) in c:_Releases\ERP\UD10.1.400.37\Source\Server\Services\BO\OrderJobWiz\OrderJobWizSvcFacade.cs:line 87
at SyncInvokeCreateJobs(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in c:\_Releases\ICE\3.1.400.37\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59 at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func2 func) in c:_Releases\ICE\3.1.400.37\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in c:_Releases\ICE\3.1.400.37\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.OrderJobWizImpl.CreateJobs(OrderJobWizDataSet ds, String& pErrorMessages)
at Erp.Adapters.OrderJobWizAdapter.CreateJobs(String& pErrorMessages)
at Erp.UI.App.OrderJobWizEntry.Transaction.CreateJobs()
