While this would never happen to our QA team, it is hypothetically possible that a customer might receive product that does not conform to spec.
In the case this is a serious issue, the existing Non-Conformance and DMR processes work well. In the case the issue is minor, the default workflow is suboptimal.
How do you recommend handling the case that the Non-Conformance is something the final customer can live with (not return for rework/replacement), but we still want to track our/supplier’s nonconformance?
The only two suggestions so far are:
- Process normally then do a quantity adjustment since nothing is actually received/shipped back - this requires an extra step and confuses demand calculations.
- Use an “Other” Non-conformance - this does not link the non-conformance to the part/lot/supplier.
Are there better solutions?
