Chances are one of the services is not running.
There are 4.
Epicor Authorization Service Lite
Secure Data Encryption Certificate Installer
Secure Data Service
Secure Data Web Service
Chances are one of these may not be running, this is aldo the order they
should be started in, and then stopped in reverse order.
If they are all running, make sure they are running with no errors, check
the error logs for each of them.
Could also be a port setup issue, or a permissions issue between the
different services.
Those are the various problems that have cropped up in the various
installations of this I have done, they are almost always a headache.
rennerke05
Sent: Saturday, February 02, 2013 7:19 PM
Subject: [Vantage] ESDM help in 701
Hi.
So we are making the leap to 701 from 606a and use ESDM for credit card
processing.
Everything is installed/upgrade and up and running except credit card
capability. When trying to authorize a card I get a error noted below:
Exception caught in: Epicor.Mfg.BO.SalesOrder
Error Detail
Message: Errors were found during the invoke of SubmitCredit:
Web service operation SubmitCredit generated a SOAP Fault. SOAP faultstring
is: System.Web.Services.Protocols.SoapException: Server was unable to
process request. ---> System.ServiceModel.FaultException: The creator of
this fault did not specify a Reason. (11506) Fault Code: Receiver Fault
String: System.Web.Services.Protocols.SoapException: Server was unable to
I've actually ripped out ESDM completely and poured over the docs to
re-install it. Same issue.
By chance anyone have any guidance?
Thanks in advance,
Kelly Renner
There are 4.
Secure Data Service
different services.
rennerke05
Hi.
processing.
Error Detail
Thanks in advance,
Kelly Renner
