Estimated Costs not pulling through in Job Entry/Tracker
I ran the Production Detail report on a job and that shows Estimated cost on materials, but when I look at the Job in Job Entry or Tracker I do not see any estimated costs on materials. What triggers that estimated cost to pull through?
What version and where are you seeing and not seeing them? I am still in classic and have never seen them not appear when I hit the retrieve.
The estimated material cost details are copied to JobMtl when the material entries are modified. If you pop over to BAQ and find costs written to Erp.JobMtl in fields with names that contain ‘cost’, then that part is working.
I’d check that from BAQ. If you’re seeing values at the database that aren’t returned by the client, then stop by assemblies > cost in job tracker and if that’s returning cost details, you might have an SSRS issue at the production detail report. If there are values at the database and they’re not returned in either of those places it’s time to bother support. If you’re not seeing values at the database, it’s an upstream bug. If you file a support ticket they’ll also want a reality check that component materials have an inventory value.
2024.2.7
We are seeing estimated material costs in Method Tracker and not seeing estimated material costs in Job Entry.
Did you run a baq or sql query on JobMtl to see if you have any costs in the table and then maybe we can help sort out how to proceed. For us most of our parts are new so they do not get good estimates, so I have a bpm that resets the estimate when we kit the job, so my estimate to actual analysis is cleaner.
