You need to map it all directions.
Here is what I have working in 8.03.409C:
Target:Source
PartOpr.checkbox01:ECOOpr.checkbox01 -- passes it to PartOpr on check-in from EWB
ECOOpr.checkbox01:PartOpr.checkbox01 -- takes it from PartOpr and brings it to EWB
JobOpr.checkbox01:PartOpr.checkbox01 -- takes it from PartOpr when details are retreived and puts it in JobOpr.
Is it possible you are missing the second link. This would never retrieve it back from the PartOpr table looking like it did not 'stick'. Just a thought.
Ross
Target:Source
Ross
--- In vantage@yahoogroups.com, Robert Carlson <rcarlson@...> wrote:
> Observed that a customized checkbox in EWB has no
> persistence when used with data. You can check
> it while in EWB but once you check the part back in, the box is erased.
> Contacted Support and they replicated the action....currently an open call.
> Bob Carlson
> bcarlson@...
> At 02:43 PM 3/28/2011, you wrote:
> >There is. The data gets passed between ECOOpr, PartOpr and JobOpr.
> >Create a customization to display the chosen
> >field in each module: EWB (ECOOpr), Method
> >Tracker (PartOpr) and Job Entry/Tracker (JobOpr).
> >Then create an entry for each of these
> >relationships in Custom Field Map in the
> >utilities folder. When you are checking a part
> >in it will relate the ECOOpr table to the
> >PartOpr table and when you are getting details
> >it will pass from the PartOpr table to the JobOpr table.
> >Ross
> >--- In
> ><mailto:vantage%40yahoogroups.com>vantage@yahoogroups.com,
> >"Bob Carlson" <rcarlson@> wrote:
> > > Is there a way to put a custom checkbox into
> > EWM/Operation and have the check mark transfer
> > over with "get details" to a Job Entry Operation?
> > > The two customizations don't have a common table to get the checkbox from.
> Robert (Bob) Carlson
> rcarlson@...
> Mobile: 603-883-8093
