ExcelOperations Library - ExcelToDataSet, DataSetToExcel
This function library does two things mainly.
- Takes an Excel binary (
.xlsx) and exports it to a DataSet. - Takes a DataSet and exports it to an Excel binary. (
.xlsx)
It also includes a helper function that will open an excel file on the server, and run it through the ExcelToDataSet function for you.
ExcelToDataSet will export all sheets in an excel file (.xlsx) to a DataSet. Each sheet get’s it’s own table.
DataSetToExcel will export all tables in a DataSet to an excel file (.xlsx). Each table get’s its own sheet.
ReadExcelFileReturnDataSet will read an excel file and run it through ExcelToDataSet and return a DataSet.
Library → ExcelOperations.efxj (17.5 KB)
Here are the guts →
References →
- DocumentFormat.OpenXml.dll
- Newtonsoft.Json.dll
- System.IO.Packaging.dll
Function → ExcelToDataSet
Signature →
| Name | Type |
| b64Data | System.String |
| hasHeaderRows | System.Boolean |
Usings →
using DocumentFormat.OpenXml;
using DocumentFormat.OpenXml.Packaging;
using DocumentFormat.OpenXml.Spreadsheet;
using Newtonsoft.Json;
Code →
Func<SpreadsheetDocument, List<string>> GetWorksheetNames = (doc) =>
return doc.WorkbookPart.Workbook.Sheets
.Elements<Sheet>()
.Select(s => s.Name?.Value)
.Where(name => name != null)
.ToList();
Func<Cell, SharedStringTable, object> GetCellValue = (cell, sharedStrings) =>
if (cell == null || cell.CellValue == null)
return DBNull.Value;
string value = cell.CellValue.Text;
if (cell.DataType != null && cell.DataType.HasValue)
CellValues dataType = cell.DataType.Value;
if (dataType == CellValues.SharedString)
int index;
if (int.TryParse(value, out index) && sharedStrings != null)
return sharedStrings.ElementAt(index).InnerText;
return value;
else if (dataType == CellValues.Boolean)
return value == "1" ? true : false;
else
return value; // inline strings etc.
else
// Try parse as int first
int intVal;
if (int.TryParse(value, out intVal))
return intVal;
// Then try date (Excel stores as OADate)
double oaDate;
if (double.TryParse(value, out oaDate) && oaDate > 0 && oaDate < 60000)
try
DateTime dt = DateTime.FromOADate(oaDate);
if (dt.Year > 1900 && dt.Year < 2100)
return dt;
catch { }
// Fallback to double
double dbl;
if (double.TryParse(value, out dbl))
return dbl;
return value;
Func<SpreadsheetDocument, string, bool, DataTable> ParseExcelFile = (xlDoc, sheet, hasHeader) =>
WorkbookPart workbookPart = xlDoc.WorkbookPart;
Sheet sheetMeta = workbookPart.Workbook.Sheets.Elements<Sheet>().FirstOrDefault(x => x.Name == sheet);
if (sheetMeta == null) throw new Exception("Sheet not found");
WorksheetPart worksheetPart = (WorksheetPart)workbookPart.GetPartById(sheetMeta.Id);
SheetData sheetData = worksheetPart.Worksheet.Elements<SheetData>().First();
SharedStringTable sharedStringTable = workbookPart.SharedStringTablePart != null
? workbookPart.SharedStringTablePart.SharedStringTable
: null;
List<Row> rows = sheetData.Elements<Row>().ToList();
if (rows.Count == 0) return null;
DataTable table = new DataTable(sheet.Replace(" ", ""));
int startRowIndex = 0;
// Use typeof(object) to allow mixed data types
if (hasHeader)
Row headerRow = rows[0];
foreach (Cell cell in headerRow.Elements<Cell>())
string columnName = GetCellValue(cell, sharedStringTable)?.ToString();
table.Columns.Add(string.IsNullOrEmpty(columnName)
? "Column" + (table.Columns.Count + 1)
: columnName, typeof(object));
startRowIndex = 1;
else
int columnCount = rows.Max(r => r.Elements<Cell>().Count());
for (int i = 0; i < columnCount; i++)
table.Columns.Add("Column" + (i + 1), typeof(object));
for (int i = startRowIndex; i < rows.Count; i++)
Row row = rows[i];
List<Cell> cells = row.Elements<Cell>().ToList();
DataRow dataRow = table.NewRow();
for (int j = 0; j < table.Columns.Count; j++)
if (j < cells.Count)
dataRow[j] = GetCellValue(cells[j], sharedStringTable);
else
dataRow[j] = DBNull.Value;
table.Rows.Add(dataRow);
return table;
#if !DEBUG
Func<string, bool, DataSet> BuildDataSetFromSpreadSheet = (b64, hr) =>
using (var memoryStream = new System.IO.MemoryStream(Convert.FromBase64String(b64)))
using (var xlDoc = SpreadsheetDocument.Open(memoryStream, false))
var listSheets = GetWorksheetNames(xlDoc);
DataSet tempDS = new DataSet();
listSheets.ForEach(x =>
tempDS.Tables.Add(ParseExcelFile(xlDoc, x, hr));
return tempDS;
#else
Func<string, bool, DataSet> BuildDataSetFromSpreadSheet = (b64, hr) => null;
#endif
//Execution begins here:
var ListErrors = new List<Exception>();
try
#if !DEBUG
Success = true;
#else
throw new BLException("Library was left in DEBUG Mode.");
#endif
ds = BuildDataSetFromSpreadSheet(b64Data, hasHeaderRows); //hasHeaderRows is global for all sheets
catch (Exception ex)
Success = false;
ListErrors.Add(ex);
finally
ListErrorsJson = JsonConvert.SerializeObject(ListErrors, Formatting.Indented);
Function → DataSetToExcel
Signature →
| Name | Type |
| ds | System.Data.DataSet |
| writeHeaderRows | System.Boolean |
Usings →
Code →
Func<object, Cell> CreateCellFromValue = (value) =>
var cell = new Cell();
if (value == null || value == DBNull.Value)
cell.DataType = CellValues.String;
cell.CellValue = new CellValue("");
else if (value is bool)
cell.DataType = CellValues.Boolean;
cell.CellValue = new CellValue((bool)value ? "1" : "0");
else if (value is int || value is long || value is float || value is double || value is decimal)
// Leave DataType null to let Excel treat it as number
cell.CellValue = new CellValue(Convert.ToString(value, System.Globalization.CultureInfo.InvariantCulture));
else
var str = value.ToString();
if (str.StartsWith("'")) // Remove Excel-style forced text apostrophe
str = str.Substring(1);
cell.CellValue = new CellValue(str);
return cell;
//Put library in debug mode while coding for the error to go away, take it off before saving
#if !DEBUG
Func<DataSet, byte[]> ExportToExcelAsBytes = (dataSet) =>
using (var stream = new System.IO.MemoryStream())
//Create Excel document
using (SpreadsheetDocument doc = SpreadsheetDocument.Create(stream, SpreadsheetDocumentType.Workbook, true))
WorkbookPart workbookPart = doc.AddWorkbookPart();
workbookPart.Workbook = new Workbook();
Sheets sheets = workbookPart.Workbook.AppendChild(new Sheets());
uint sheetId = 1;
//Loop through each table in the dataset
foreach (DataTable table in dataSet.Tables)
WorksheetPart worksheetPart = workbookPart.AddNewPart<WorksheetPart>();
SheetData sheetData = new SheetData();
worksheetPart.Worksheet = new Worksheet(sheetData);
if(writeHeaderRows)
// Header row
Row headerRow = new Row();
foreach (DataColumn col in table.Columns)
headerRow.AppendChild(CreateCellFromValue(col.ColumnName));
sheetData.AppendChild(headerRow);
// Data rows
foreach (DataRow row in table.Rows)
Row newRow = new Row();
foreach (var item in row.ItemArray)
newRow.AppendChild(CreateCellFromValue(item));
sheetData.AppendChild(newRow);
string relId = workbookPart.GetIdOfPart(worksheetPart);
sheets.Append(new Sheet
Id = relId,
SheetId = sheetId++,
Name = table.TableName
workbookPart.Workbook.Save();
return stream.ToArray(); //Return byte array
#else
Func<DataSet, byte[]> ExportToExcelAsBytes = (dataSet) => null;
#endif
try
#if !DEBUG
Success = true;
#else
#endif
b64Data = Convert.ToBase64String(ExportToExcelAsBytes(ds));
Success = false;
ListErrors.Add(ex);
finally
Function → ReadExcelFileReturnDataSet
Signature →
| Name | Type |
| inServerFolder | System.Int32 |
| inFileName | System.String |
| hasHeader | System.Boolean |
Usings →
none
Code →
var sb = (ISandbox)Sandbox;
var serverFolder = (ServerFolder)inServerFolder;
var filePath = new FilePath(serverFolder, inFileName);
var excelFileBytes = sb.IO.File.ReadAllBytes(filePath);
var excelFileAsB64 = Convert.ToBase64String(excelFileBytes);
var processExcel = ThisLib.ExcelToDataSet(excelFileAsB64, hasHeader);
if(processExcel.Success)
ds = processExcel.ds;
Example here →
