-E9. from main menu bar, Options --> "Clear Client Cache"
I have used this to resolve a lot of unexplained behavior.
--- In vantage@yahoogroups.com, "Ned C." <TechnoBabbly@...> wrote:
> When you do the actual install, does the entire contents of the client
> folder get filled?
> This is often an error from the auto-update not running correctly.
> Local permissions on the Documents and Settings folders are not allowing the
> full permissions to write the local files.
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Adele
> Sent: Friday, March 02, 2012 4:55 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Exception has been thrown by the target of an invocation
> Hi,
> We are on Epicor 9.04.506C.
> I have a user that is trying to use Epicor for the first time. His PC has
> had Epicor installed on it for a couple of years as it came from a previous
> user. When he tried to open his client, he got the following error:
> Error Detail
> Server execution failed (Exception from HRESULT: 0x80080005
> (CO_E_SERVER_EXEC_FAILURE))
> Stack Trace
> at
> System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32
> errorCode, IntPtr errorInfo)
> at System.Management.ManagementEventWatcher.Start()
> at Epicor.Mfg.Lib.NetworkMonitor.watchEvent(String eventName)
> at Epicor.Mfg.Lib.NetworkMonitor.Start()
> at Epicor.Mfg.UI.Suspend..ctor(Form mainForm, Session session)
> at Epicor.Mfg.UI.MenuForm.loadUserSettings(String userID)
> at Epicor.Mfg.UI.MenuForm.SetupComponent()
> at Epicor.Mfg.UI.App.Launch.ShowMenuForm()
> at Epicor.Mfg.UI.App.Launch.ShowDialog(String[] args)
> I tried to uninstall his client but got an error that said:
> Error 1606. Could not access network location INSTALLDIR.
> I verified he has access to all of the network shares and then tried to
> uninstall the client from his PC as a domain admin. However, logged in as
> the administrator, it didn't even show that Epicor was installed on the PC.
> I finally got it uninstalled by running the install again from the network
> and choosing Remove instead of change or repair.
> Once I got it reinstalled, I once again tried to open the client. I now get
> Exception has been thrown by the target of an invocation.
> I have tried running as the administrator and have tried running it for a
> couple of environments with the same result.
> If anyone has any ideas, they would be greatly appreciated.
> Thanks!
> Adele
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
I deleted an unused decimal box from a configurator. There is no reference to the decimal box in any of my AppServer code. Now if I try to test inputs in Configurator Designer I get the "Exception has been thrown by the target of an invocation" error message. Anyone know why I'm getting this error and how to resolve it? I'm on Epicor 9 version 905.701.
Try clearing your PCrules files, things get “stuck†in there and will continue to be part of your compile for some reason.
Brenda
Sent: Wednesday, August 26, 2015 3:13 PM
