Thanks Jose,
Yes, a BPM is good in the update cases, but the example I used is just one among a few. I am validating data as the user enters fields and I want to catch it then, not wait for the update.
- Neil
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Friday, 14 September 2012 9:08 AM
Subject: Re: [Vantage] Exception in VB to prevent invalid data entry
Bpm is a more appropriate solution ford this problem.
It covers Allen the cases, pre processing on update should it On Sep 13, 2012 6:45 PM, "nbuckman@..." < nbuckman@...> wrote:
Notice:This e-mail and any attachments are confidential and are only for the use of the person to whom they are addressed. If you are not the intended recipient please advise the sender by return e-mail and delete the message and any attachments. Any use, interference with, disclosure or copying of this message or any attachments is unauthorised and prohibited. The sender does not warrant that the information is free of a virus or any other defect or error, and any views expressed herein, unless specifically indicated otherwise, are those of the individual sender.
The DH Gibson Group of Companies - http://www.gibsonshopfitters.com.au
P Please consider our shared environment before printing this communication.
- Neil
> **[Non-text portions of this message have been removed]
> Hello,
> I have some VB code like this in a customisation. It works when an
> invalid part is first entered in the field, but if the user
> immediately re-enters the invalid code then the exception does not
> happen. How do I restart the process, so to speak, so that you can't get past it?
> Private Sub UD100_AfterFieldChange(ByVal sender As Object, ByVal args
> As
> DataColumnChangeEventArgs)
> ....code here....
> Select Case args.Column.ColumnName
> Case "ShortChar01"
> ....code here.....
> If PartFound = True then
> ....code here...
> Else
> MessageBox.Show(PartNum + "is not a valid part number.
> Please retry...")
> Throw new UIException()
> End If
> End Select
> End Sub
