We are currently conducting a data cleanse to remove duplicated entries and tidy up records to provide consistent data. Is there an exception report within Epicor, that I could run to show where chosen boxes are empty, on for example a supplier record, or is this something I need to write?
You’ll need to make a BAQ. Unless the expected results are bigger than 20,000 records or so, you won’t need to make a BAQ report or Dashboard. You can run it in BAQ Designer. and then right click in the results to send them to Excel.
