We’re getting requests to slice and dice parts and data lots of different ways, and doing all we can to not create more UD fields every time.
This time, we’re purchasing a part, which is taken apart, and we inventory the breakdown parts. The top level purchased part looks like it isn’t sold often, so it keeps getting added to the run-out eligible list, but we use the sub-parts. Is there a better way to identify these than adding a sub-kit UOM?
If these parts have Methods/Revisions you can instead check one of your Method Related fields to limit your Run-Out List (Assuming your run out list is a BAQ):
-LowLevelCode (lowest level the part shows up in another method)
-Method boolean value if the part has a method or not.
-Perhaps you can check the activity of the related method?
-Or include purchase history in the Run Out eligible BAQ.
To avoid adding UD fields, I will sometimes use User Codes, adding a User Code record with a certain User Code Type value. I setup the Code Type to auto sequence and I set the Part number in the Description field (short description). This way I can maintain multiple endless lists of different types of parts. Makes it easy to query too for Dashboards and BAQ Searches.
