Hi everyone,
In preparation for our upcoming upgrade to Kinetic, we are exploring the possibility of creating new labels in advance.
Does anyone have any recommendations for barcode fonts that work well with Kinetic?
Hi everyone,
Hi,
Generally Code39 and code128 are the most common ones used.
As barcodes are merely a quick way of typing characters I would imagine Kinetic is fairly agnostic as to the type used.
A bigger consideration what your scanners can read and your barcode printers can print.
Other considerations are the bar code size and the label size used.
Finally, if you want SSRS to print the bar codes make sure you have the font installed in SSRS.
Cheers,
Andrew.
Thanks mate…
