Exported Crystal Reports
Put the msvcrt.dll on a floppy, boot to dos using a dos boot disk, manually
copy msvcrt.dll to the right folder. Also, with a bit of googling you can
find some small .bat programs to install it at reboot.
Shirley Graver
Rubber Associates
Tracking #: 27C060A8540F8B4DB75282D7AEADCB67FFC5FDD4
We've successfully written custom reports in v8.5 for Vantage 5.2.
I've exported one using the report distribution expert. I've
successfully installed it on a couple client computers. The users can
click the shortcut icon to the custom report and it will open the
report. But... when I click refresh data and/or modify selection
criteria a logon window pops up, very similar to the ODBC window seen
when refreshing a crystal report. The proper username is in place but
the password will not work. Any ideas why? I tried setting up ODBC
connectivity on both computers and can do the Test Connection and it
is successful with the same username and password.
Bruce Brannan
Engineered Products Dept.
Bruce,
You have to run the ODBCFix patch for Crystal Reports on each
workstation where you install a custom Crystal Report. I believe support
will provide you with that patch.
Todd Hofert
IT Director
Spartan Graphics, Inc.
Sent: Wednesday, March 02, 2005 11:36 AM
Subject: [Vantage] Exported Crystal Reports
connectivity on both computers and can do the Test Connection and it is
Bruce Brannan
Yahoo! Groups Links
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
Thanks for the response. Here's what I've learned: ODBC has to be
configured on each machine, with consistent setup to the machine that
exported the report.
The new problem I've encountered is with the Crystal runtime version
install. There are a couple dll files that cannot be overwritten
because they are open. I've tried booting into safe mode but the
msvcrt.dll file still remains open. I've been told that explorer is
using it but have a couple of the installs were successful while
others weren't. I can hit the ignore button and the software will
complete but when I run the report I get a dll error. I found tech
support topics on MS and Crystal's website but neither give a
explanation of how to fix this. Any ideas?
Bruce
--- In vantage@yahoogroups.com, "Todd Hofert" <todd@s...> wrote:
> Bruce,
> Todd Hofert
> IT Director
> From: brucewbrannan [mailto:bruce.brannan@w...]
> Thanks,
> Bruce Brannan
> Yahoo! Groups Links
