Can the DMT tool be used to extract data out of our TEST database to then load in our LIVE environments database? I can't find any material or posts that say DMT can be used to extract data, everything I find says it is a data import tool only.
Thank you
Jose C Gomez
T: 904.469.1524 mobile
On Fri, Jun 5, 2015 at 9:20 AM, detroitrdwings91@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p><span><br></span></p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">Can the DMT tool be used to extract data out of our TEST database to then load in our LIVE environments database? I can't find any material or posts that say DMT can be used to extract data, everything I find says it is a data import tool only.</p><p><span></span></p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">Thank you</p><p><span><br></span></p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
On Fri, Jun 5, 2015 at 8:20 AM, detroitrdwings91@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p><span><br></span></p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">Can the DMT tool be used to extract data out of our TEST database to then load in our LIVE environments database? I can't find any material or posts that say DMT can be used to extract data, everything I find says it is a data import tool only.</p><p><span></span></p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">Thank you</p><p><span><br></span></p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
I don’t know that it’s an effective use of time for them to develop that. For that purpose we just create BAQs that dump the data and make the column names what DMT wants. Put it in a Dashboard, export to excel whenever needed and call it good. Gives us the ability to add any filtering before we dump it too to control what we get. It takes some internal time to do that but not long and you have it forever available.
Joshua Giese
CIO
Direct: 920.593.8299
IT Dept: 920.437.6400 Ext. 337
Site ID: 27450-E905702A-SQL64
Wisconsin Converting, Inc.
Sent: Friday, June 5, 2015 8:25 AM
To: Vantage
Subject: Re: [Vantage] Extract with DMT in Epicor 10??
At the moment it just imports data, I believe they were working on getting some export functionality but it isn't on there at the moment
Jose C Gomez
Software Engineer
T:
904.469.1524 mobile
Thank you
If doing an extract to do a transfer were a good idea, it would be a better use to have it do the transfer for you.
As said, the query is a better route because you can then dump (or schedule the dump) the query and then edit the data before entering it.
Charlie Smith
CTCharlie@...
Cell: 860-919-1708
Office: 817-862-9862
Sent: Friday, June 05, 2015 8:51 AM
No extract in DMT, but you can run a query for the pretty much the same data. If you get over 10,000 rows back you'll need to access it from a dashboard.
Extracting from DMT would be cool because it would return data from more than one table, since inputting info that way disperses it among multiple tables in many cases.
To transfer from Test to Live I suppose you would need to get all the fields from a given DMT input and join the proper files in a query to get that output.
Joe Trent
Thank you
