As anyone done integration with Faire.com API? Can you recommend a developer.
Thanks!
Thanks!
What type of integration are you trying to achieve?
A little more context goes a long way.
Sorry for the lack of context.
We are currently in version 2022.2.16 on prem.
We are currently entering Faire.com orders manually or via DMT.
We have some custom that creates orders in Epicor from a 2 tab files (header and lines).
We would like to take advantage of the Faire API to create the tab files in the same format so it can use our existing custom and create the orders in Epicor.
Let me know if you need more information.
Thanks.
You’re probably best taking a look at Automation Studio.
There is several boilerplates to work with.
You can tie Faire.com with Kinetic ERP.
I suggest using the BigCommerce and modifying it to use Faire’s endpoints. Obviously, you will need to remap the fields.
Let us know how you get on.
This would be direct integration between Kinetic and Faire
1 → 1
You can monitor the endpoint if it’s a custom endpoint from Faire to get new orders. If any new orders then process them into Kinetic
The Modern Leader in Automation | Workato
Notice: Connectors are not cheap. You would require two connectors
Thank you for the suggestion Aaron, we will take a look at Automation Studio.
