Faster search using external program
I can see why, that really cuts down on the time to return the dataset. I'm only interested in 5 or 6 columns to display in the dataview, that was very useful.
Sent: Friday, November 11, 2011 3:02 PM
Subject: Re: [Vantage] Re: Faster search using external program
No prob,
I try to use that as much as I can, it cuts down on the amount of data that
is received from the BO, if you do a GetRows you are returning every Table
and child combination and its just plain slow. When most of the time all
you need is the PK and a Description.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>Â <http://www.facebook.com/josegomez>
On Fri, Nov 11, 2011 at 2:54 PM, Ted Koch <tkoch77@...> wrote:
> That was it. Needed ds.tables(0) and then it worked. I was confused
> because it was returning a dataset. Thanks again for the help Jose, that
> cut the search down to less then 2 seconds.
> From: Jose Gomez <jose@...>
> Sent: Friday, November 11, 2011 2:46 PM
> Try this
> grid.DataSource=ds.Tables[0]
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
>Â <http://www.google.com/profiles/jose.gomez> <
>Â <http://www.josecgomez.com/professional-resume/>
>Â <http://www.usdoingstuff.com>
> On Fri, Nov 11, 2011 at 2:34 PM, Jose Gomez <jose@...> wrote:
> > Did you step through and saw that you are getting data back?
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > <http://www.linkedin.com/in/josecgomez> <
> >Â <http://www.josecgomez.com/professional-resume/> <
> > On Fri, Nov 11, 2011 at 2:29 PM, Ted Koch <tkoch77@...> wrote:
> >> Ive been trying to bind this to a datagrid view but nothing happens when
> >> I do this.
> >> Dim _boReader As New BOReader(epiSession.ConnectionPool)
> >>Â Â Â Â Â Â Dim ds As DataSet = _boReader.GetList("Part",
> >> "Part.Company='100' and Part.PartNum = '" & partnum & "'Â ", "partnum")
> >>Â Â Â Â Â Â 'ComboBox1.ValueMember = "CustNum"
> >>Â Â Â Â Â Â DataGridView1.DataSource = ds
> >> Am I missing something?
> >> From: Ted Koch <tkoch77@...>
> >> To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
> >> Sent: Friday, November 11, 2011 2:07 PM
> >> Found it, when i was typing in the filename box in add reference it
> wasnt
> >> showing at first.
> >> Sent: Friday, November 11, 2011 2:02 PM
> >> What is the path to lib.boreader and lib.iboreader. I didnt see it in
> the
> >> client folder?
> >> Sent: Friday, November 11, 2011 1:56 PM
> >> Use the BOReader
> >> Bring in Lib.BoReader and Lib.IBOReader
> >> use it as such
> >> BOReader _boReader = new BOReader(_session.ConnectionPool);
> >>Â Â Â Â Â Â Â Â Â Â Â Â DataSet ds = _boReader.GetList("Part",
> >> "Part.Company='CO' and Part.PartNum='PNUM'",
> "Key1,Key2,Key3,Key4,Key5");
> >> Key1, key2 etc.. is a list of the fields you'd like returned.
> >> *Jose C Gomez*
> >> *Software Engineer*
> >> E: jose@...
> >> On Fri, Nov 11, 2011 at 1:53 PM, Ted Koch <tkoch77@...> wrote:
> >> > I'm running progress
> >> > From: Tim Vonderhaar <tvonderhaar@...>
> >> > Sent: Friday, November 11, 2011 1:51 PM
> >> > Subject: [Vantage] Re: Faster search using external program
> >> > Writing direct SQL queries has been a Godsend for me. I had the same
> >> > problem when I needed to read the entire Customer table. Doing it via
> >> > Service References was incredibly slow. As long as I don't need to
> >> change
> >> > data, I opt for bypassing all the layers and get the data directly.
> >> > --- In vantage@yahoogroups.com, "tkoch77" <tkoch77@...> wrote:
> >> > > Is there any way to make an external search of the epicor database
> >> > faster? Right now I'm searching the part table and it takes probably
> >> about
> >> > 8 seconds and there are 1100 parts in there currently and that number
> >> will
> >> > always be growing.
> >> > > Thanks,
> >> > > Ted
> >> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must
> >> > have already linked your email address to a yahoo id to enable
> access. )
> >> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> >> and
> >> > Crystal Reports and other 'goodies', please goto:
> >> > http://groups.yahoo.com/group/vantage/files/.
> >> > (2) To search through old msg's goto:
> >> > http://groups.yahoo.com/group/vantage/messages
> >> > (3) To view links to Vendors that provide Vantage services goto:
> >> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> >> > [Non-text portions of this message have been removed]
> >> have already linked your email address to a yahoo id to enable access. )
> and
> and
> and
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
Is there any way to make an external search of the epicor database faster? Right now I'm searching the part table and it takes probably about 8 seconds and there are 1100 parts in there currently and that number will always be growing.
Ted
What fields are you searching on? If you can stick to the indexes, it will
help performance.
How are you searching? ODBC? Web services? How big is your result set?
> always be growing.
> Thanks,
> Ted
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
My search criteria is company and part number right now, and that returns 1 part. The whole connection is coded using epicor.mfg.core.session and blconnectionpool and the part BO.
Sent: Friday, November 11, 2011 1:45 PM
Subject: Re: [Vantage] Faster search using external program
help performance.
> always be growing.
> Thanks,
> Ted
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Writing direct SQL queries has been a Godsend for me. I had the same problem when I needed to read the entire Customer table. Doing it via Service References was incredibly slow. As long as I don't need to change data, I opt for bypassing all the layers and get the data directly.
> Thanks,
> Ted
> Thanks,
> Ted
Use the BOReader
use it as such
"Part.Company='CO' and Part.PartNum='PNUM'", "Key1,Key2,Key3,Key4,Key5");
*Jose C Gomez*
*Software Engineer*
E: jose@...
> always be growing.
> > Thanks,
> > Ted
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
What is the path to lib.boreader and lib.iboreader. I didnt see it in the client folder?
Use the BOReader
use it as such
*Jose C Gomez*
*Software Engineer*
E: jose@...
> always be growing.
> > Thanks,
> > Ted
Found it, when i was typing in the filename box in add reference it wasnt showing at first.
Use the BOReader
use it as such
*Jose C Gomez*
*Software Engineer*
E: jose@...
> always be growing.
> > Thanks,
> > Ted
Ive been trying to bind this to a datagrid view but nothing happens when I do this.
           Dim ds As DataSet = _boReader.GetList("Part", "Part.Company='100' and Part.PartNum = '" & partnum & "' ", "partnum")
Use the BOReader
use it as such
*Jose C Gomez*
*Software Engineer*
E: jose@...
> always be growing.
> > Thanks,
> > Ted
*Jose C Gomez*
*Software Engineer*
E: jose@...
> do this.
> showing at first.
> client folder?
> Use the BOReader
> use it as such
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> change
> about
> will
> > always be growing.
> > > Thanks,
> > > Ted
Try this
*Jose C Gomez*
*Software Engineer*
E: jose@...
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
>> I do this.
>> showing at first.
>> client folder?
>> Use the BOReader
>> use it as such
>> *Jose C Gomez*
>> *Software Engineer*
>> E: jose@...
>> change
>> about
>> will
>> > always be growing.
>> > > Thanks,
>> > > Ted
>> and
That was it. Needed ds.tables(0) and then it worked. I was confused because it was returning a dataset. Thanks again for the help Jose, that cut the search down to less then 2 seconds.
Try this
*Jose C Gomez*
*Software Engineer*
E: jose@...
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
>Â <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
>Â <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
>> I do this.
>> showing at first.
>> client folder?
>> Use the BOReader
>> use it as such
>> *Jose C Gomez*
>> *Software Engineer*
>> E: jose@...
>> change
>> about
>> will
>> > always be growing.
>> > > Thanks,
>> > > Ted
>> and
>>Â
No prob,
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Try this
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> >> I do this.
> wasnt
> >> showing at first.
> the
> >> client folder?
> >> Use the BOReader
> >> use it as such
> >> *Jose C Gomez*
> >> *Software Engineer*
> >> E: jose@...
> >> change
> >> about
> >> will
> >> > always be growing.
> >> > > Thanks,
> >> > > Ted
> access. )
> >> and
> and
> and
> and
