I use variations of this is several places:
Directive 1 – Set <YourField> to ttCallContextBPMData.ShortChar01
Set ttCallContextBPMData.Checkbox01 = FALSE.
Directive 2 – ABL Code:
IF Length(ttCallContextBPMData.ShortChar01) = 10 THEN Assign ttCallContextBPMData.Checkbox01 = TRUE.
Directive 3 – If ttCallContextBPMData.Checkbox01 = FALSE Raise Exception.
Brenda
vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
Jose Gomez
Sent: Friday, February 07, 2014 10:13 AM
To: Vantage
Subject: Re: [Vantage] Field Validation Epicor 905.701
you can limit the length of a field in extended properties maintenance.. but there is no "Syntax.. for it" not sure what you mean by that.. You can write some custom code also, or use a BPM
Jose C Gomez
Software Engineer
T:
904.469.1524 mobile
Quis custodiet
ipsos custodes?
On Fri, Feb 7, 2014 at 10:09 AM, <whitenight922@...> wrote:
Does anyone know the syntax for the field validation for 905? Basically I'm looking for it to check the number of characters in a field. I tried len = 10, but that doesn't seem to be working.
Thank you!
