File for "Lock Date" which is a "Logic Field" on PO line-release scr
Good Day:
RE: File for "Lock Date" which is a "Logic Field" on PO line-release
screen
I want to look for all PO's with the line-release "Lock Date" field
checked; but it is a 'logic' field- that is, the field help does not
give the File:Field name.
Similar to "primary Vendor"
So the checkbox is not a field, just a condition that causes the Vendor
to be stored in the other (PartPlant) file.
So, the Vendor in PartPlant is the Primary
Vendor.
Does anyone know what field the "Lock-Date" fields causes to get
updated so I can run a report?
Sun is on 9.05.605 since 10/2/11 - SQL-Unidata
Live on 9.05.601B since 11/29/10
Sun was previously on M2K (Manage-2000) 7.0 SP 5 (Informix)
len.hartka@...
<blocked::blocked::mailto:len.hartka@...>
Leonard C. Hartka, IS Project Manager\ERP Specialist
Sun Automation Group
66 Loveton Circle
Sparks, Md. 21152
410-329-3560 ext. 120
410-329-3564 FAX
443-255-7192 Work Cell
len.hartka@...
www.Sunautomation.com <blocked::blocked::http://www.sunautomation.com/>
Celebrating
25 Years of Service
to the Corrugated Industry
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
