Hi,
Thanks for the below
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> Dont know what version you are on, but in 8.03.405 I would add an
> event handler for the before dropdown event for list 2. In there I
> would do a list lookup on CustCnt and create the whereclause using
> the selected value from list 1 and bind the resulting data to the
> combo - you can set up your column filters so you only display the
> columns you want in the form load event.
> bw
> --- In vantage@yahoogroups.com, "brychanwilliams"
> <brychanwilliams@> wrote:
> > Good afternoon,
> > I have a combo(list1) which lists customers . I would like to
have
> > another combo list which contains only the contacts(list2)
related
> to
> > the customer selected in List1.
> > A database field will get populated on daving but most of the
> > interaction will be in the user interface.
> > Prsently, I have an ultracomb attached to the customer adapter to
> list
> > the customers(list1).
> > I have a combo listing customer contacts but I can't work out to
> filter
> > that depending on which customer is selected. I can filter combo
> (list2)
> > fixing the custnum but not on the selection.
> > Any help would be great.
> > Many thanks
