Finding remaining QTY on a PO line?
Does anybody know the endpoint that would be best suited to find this information? Using it in an automation process and wanting to do remaining qty calculations from Epicor.
Thank you,
You could write a query on the PORel table.
and do a calculated field of PORel.ReceivedQty - PORel.XRelQty
select
[PORel].[PONum] as [PORel_PONum],
[PORel].[POLine] as [PORel_POLine],
[PORel].[PORelNum] as [PORel_PORelNum],
[PORel].[XRelQty] as [PORel_XRelQty],
[PORel].[ReceivedQty] as [PORel_ReceivedQty]
from Erp.PORel as PORel
where (PORel.ReceivedQty <> PORel.XRelQty)
Appreciate the response!
Was able to find the solution based off what you recommended :smile:
