I am trying to figure out why in E9 you have to input a value in a dec box and then tab out in order to get it to process the expression.
All of the configurations I have in Vantage 8 process by just tabing out of the box - no input is done at all. The on leave rule is at the field level and works fine.
Most of these are 1 page configurations. I have tried them both ways with the do not process on leave when load turned on and off. On difference in the processing. Won't work either way.
In the tech guide for the configurator it shows the set up as I have it in the parts.
My new simple test part has the following:
dec4 = (dec18w + dec18p). Even this will not process unless I put the On Leave rule with the dec4 field and I still have to input some kind of positive value in the dec4 field then tab to get it to process.
In Vantage 8 I could have this on leave rule with the dec18w field and tab from there to populate the result in dec4.
Is this something "new" in E9?
Gene
Gene
