If you use your query to find the last invoice, can you filter by the year (I just use the fiscal year field) in your dashboard or Crystal or whatever you're using to display the information?
--- In vantage@yahoogroups.com, Jonathan Lang <lsbestinc@...> wrote:
> I tried that. The problem is that I want to eliminate the customers who ordered in 2009 and keep the ones that ordered prior to 2009. When I do a formula based off of {Invoice.Date} it just eliminates the "Records" not the "Customer".
> --- On Thu, 9/17/09, Kirstin <kirstin.brandt@...> wrote:
> From: Kirstin <kirstin.brandt@...>
> Subject: [Vantage] Re: Formula
> To: vantage@yahoogroups.com
> Date: Thursday, September 17, 2009, 10:37 AM
> Â
> It looks like you're trying to create some kind of Inactive Customer report? Can you link to invchead using last and then filter for the year <> 2009?
> --- In vantage@yahoogroups .com, Jonathan Lang <lsbestinc@ ..> wrote:
> > I need a formula that does the following:
> > Â
> > Exclude {Customer} if Year({InvoiceDate} ) = 2009Â
> > Â
> > Can anyone help with this one?
> > Â
> > Jonathan LangÂ
> > Oil Rite Corporation
> > Sr. Network Administrator
> > Ph: (920) 682-6173 Ext: 126
> > Fax: (920) 682-7699
> > Â
