Is there a way to search for jobs that are firmed but unreleased jobs?
COM-CustUnreleasedFirmJobs.baq (30.7 KB)
You can import this BAQ and use BAQ Search
Thanks for sharing the baq, unfortunately, the version doesn’t match so I am getting an error. Would you please share the SQL
this is the error
Import From File “C:\Users\Jkrishna\Desktop\COM-CustUnreleasedFirmJobs.baq”
System.Exception: Import file doesn’t exist
at Ice.Lib.BAQExportImport.BaqExportImport.Import(ImportArgs args)
Query import finished with error(s)
I actually copied the CustomerJobs BAQ and added the conditions to it.
select
[JobHead].[JobNum] as [JobHead_JobNum],
[OrderRel].[PartNum] as [OrderRel_PartNum],
[OrderRel].[RevisionNum] as [OrderRel_RevisionNum],
[SalesRep].[Name] as [SalesRep_Name],
[JobProd].[ProdQty] as [JobProd_ProdQty],
[JobProd].[ShippedQty] as [JobProd_ShippedQty],
[JobProd].[OrderNum] as [JobProd_OrderNum],
[JobProd].[OrderLine] as [JobProd_OrderLine],
[JobProd].[OrderRelNum] as [JobProd_OrderRelNum],
[OrderRel].[OpenRelease] as [OrderRel_OpenRelease],
[OrderDtl].[LineDesc] as [OrderDtl_LineDesc],
[OrderRel].[OurReqQty] as [OrderRel_OurReqQty],
[OrderDtl].[IUM] as [OrderDtl_IUM],
[OrderRel].[NeedByDate] as [OrderRel_NeedByDate],
[OrderRel].[ReqDate] as [OrderRel_ReqDate],
[JobHead].[ReqDueDate] as [JobHead_ReqDueDate],
[JobHead].[StartDate] as [JobHead_StartDate],
[JobHead].[DueDate] as [JobHead_DueDate],
[JobHead].[JobFirm] as [JobHead_JobFirm],
[JobHead].[JobEngineered] as [JobHead_JobEngineered],
[JobHead].[JobReleased] as [JobHead_JobReleased],
[JobHead].[JobComplete] as [JobHead_JobComplete],
[JobHead].[JobClosed] as [JobHead_JobClosed],
[JobHead].[JobHeld] as [JobHead_JobHeld],
[JobHead].[Plant] as [JobHead_Plant],
[OrderHed].[CustNum] as [OrderHed_CustNum],
[JobHead].[Company] as [JobHead_Company],
[JobProd].[Company] as [JobProd_Company],
[OrderDtl].[Company] as [OrderDtl_Company],
[OrderHed].[Company] as [OrderHed_Company],
[OrderRel].[Company] as [OrderRel_Company],
[JobHead].[LastChangedBy] as [JobHead_LastChangedBy],
[JobHead].[JobWorkflowState] as [JobHead_JobWorkflowState],
[JobHead].[LastChangedOn] as [JobHead_LastChangedOn]
from Erp.JobProd as JobProd
inner join Erp.JobHead as JobHead on
JobProd.Company = JobHead.Company
and JobProd.JobNum = JobHead.JobNum
and ( JobHead.JobFirm = true and JobHead.JobReleased = false )
left outer join Erp.SalesRep as SalesRep on
JobHead.Company = SalesRep.Company
and JobHead.JobCSR = SalesRep.SalesRepCode
inner join Erp.OrderHed as OrderHed on
JobProd.Company = OrderHed.Company
and JobProd.OrderNum = OrderHed.OrderNum
inner join Erp.OrderRel as OrderRel on
JobProd.Company = OrderRel.Company
and JobProd.OrderNum = OrderRel.OrderNum
and JobProd.OrderLine = OrderRel.OrderLine
and JobProd.OrderRelNum = OrderRel.OrderRelNum
inner join Erp.OrderDtl as OrderDtl on
OrderRel.Company = OrderDtl.Company
and OrderRel.OrderNum = OrderDtl.OrderNum
and OrderRel.OrderLine = OrderDtl.OrderLine
order by JobHead.Company, JobHead.JobNum Desc
