CallService is better-encapsulated … it’s simpler syntax and handles disposing the object when you’re done. Use that one.
Something that might be helpful for prototyping, especially if you want to use mainly widgets for the BO calls in your functions, at the risk of a little self-promotion: I’ve been using my own Python library for prototyping Epicor Functions. It’s been pretty helpful to me. e.g.,
def quote_update_price(epi, quotenum, quoteline, newprice):
# this is a rough draft of the function created in Epicor
print("Updating price...")
r = epi.Erp.BO.QuoteSvc.GetByID(QuoteNum=quotenum)
r.raise_for_status()
ds = r.json()['returnObj']
for i, l in enumerate(ds['QuoteDtl']):
if l['QuoteLine'] == quoteline:
quoteline = i
break
ds['QuoteDtl'][quoteline]['DocDspExpUnitPrice'] = newprice
ds['QuoteDtl'][quoteline]['RowMod'] = 'U'
r = epi.Erp.Bo.QuoteSvc.GetDtlUnitPriceInfo_User(skipDiscLookup=True, preserveAmt=True, pIsGridPasting=False, pChangedByUser=True, ds=ds)
ds = r.json()['parameters']['ds']
r = epi.Erp.BO.QuoteSvc.Update(ds=ds)
print("Done.")
It helps me more quickly figure out which BOs and services I need to touch and which fields are required versus optional for each call. (Like that call to QuoteSvc.GetDtlUnitPriceInfo_User() in the example above.)
Something like this? It seems to work the same for the very extensive and thorough testing I’ve done.
Erp.Tablesets.PartTableset partTS = new Erp.Tablesets.PartTableset();
try
this.CallService<Erp.Contracts.PartSvcContract> (boPart =>
boPart.GetNewPart(ref partTS);
var boPartRow = partTS.Part[0];
boPartRow.PartNum = partNum;
boPartRow.PartDescription = partDesc;
boPartRow.NonStock = true;
boPartRow.MfgComment = "WS";
boPartRow.ClassID = "IS";
boPartRow.IUM = "EA";
boPartRow.PUM = "EA";
boPartRow.SalesUM = "EA";
boPart.ChangePartTypeCode(partType, ref partTS);
boPart.GetNewPartRev(ref partTS,partNum,"","");
var boPartRev = partTS.PartRev[0];
boPartRev.RevisionNum = partRev;
boPartRev.RevShortDesc = "Original Rev";
boPartRev.RevDescription = "Original Rev";
boPartRev.Plant = "MfgSys";
boPart.ChangePartRevApproved(true,true,ref partTS);
boPart.Update (ref partTS);
catch
output = "Dohh!";
