Fw: EMployee master file
I don't have the payroll module but in the employee setup file if there is a list view as well you should be able to paste/edit those as well
--- On Mon, 6/8/09, Deepa <deepait_10@...> wrote:
Subject: Re: Fw: [Vantage] EMployee master file
Date: Monday, June 8, 2009, 10:04 AM
If i do import(copy/ paste) through excel sheet in shop employee master file, it will contain only shop employee records.
But i want to import all the employee in our company not only shop employee.
For importing payroll employee, there is employee master in setup of Payroll module.
My question is how we can import the employee in that employee master file or where we can keep the record of payroll employee if we don't import in employee master file?
Thank you & Regards,
Deepa.M
____________ _________ _________ __
To: vantage@yahoogroups .com
Sent: Sunday, June 7, 2009 6:20:10 PM
In the List View tab on the Shop Employee file you can paste/edit from a csv/excel file all the employees. is that what you want to do?
--- On Sun, 6/7/09, Deepa <deepait_10@ yahoo. com> wrote:
Subject: Fw: [Vantage] EMployee master file
Date: Sunday, June 7, 2009, 2:35 AM
Hi,
Is there any updates on the below mail for uploading employee masters in Epicor 9.04.503B.
In addition to that mail there are lot of shop employees in the employee master file. so if we import into employee master file,only shop employee should be reflected in shop employee master file.
Deepa.M
----- Forwarded Message ----
Sent: Wednesday, June 3, 2009 12:18:30 PM
Subject: [Vantage] EMployee master file
Hi,
In Epicor 9.04.503B, Is there any format to import employee master file into system.
As there are 500 employees, we cannot enter manually in the system.
Will you please provide the format or any method to import into the system
Thank You & Regards,
Deepa.M
Hi,
Deepa.M
Hi,
Deepa.M
Hi,
Deepa.M
Hi,
Deepa.M
If i do import(copy/paste) through excel sheet in shop employee master file, it will contain only shop employee records.
Deepa.M
Hi,
Deepa.M
Hi,
Deepa.M
