Delores,
Sounds like you want a Cross-tab in your Crystal Report.
1. Select all records greater or equal to than 01/01/2009
2. Create a variable for Month
3. Create a Variable for Year
4. Insert a Cross-Tab into the report footer
5. Right Click on the Cross tab
6. Drag Customer Number into the rows box
7. Drag the Month Variable into the rows box under Customer number
8. Drag Year variable into the Columns Box
9. Drag the field you want to summarize into the Summarized fields
box.
10. Click on OK
11. Refresh the report
When 2010 starts this will automatically add another column.
All that is left to do is formatting.
Hope this helps
Dale E. Schuerman
Senior Consultant
Epicor Certified Consulting Partner
RAM Software Systems, Inc.
972-669-0763 x233 (voice)
972-669-9603 (fax)
mailto:dale.schuerman@...
<BLOCKED::blocked::mailto:dale.schuerman@...> (email)
http://www.ramsys.com <BLOCKED::blocked::http://www.ramsys.com/>
(website)
--- On Tue, 2/17/09, Hernandez, Dolores <dhernandez@...
Subject: [Vantage] FW: help
Date: Tuesday, February 17, 2009, 4:51 PM
I have to create a report that allows me to compare totals for
customers by month. Example: I want to be able to pull up the total
for customer ABC for Jan 1 -31, 2008 and bring up the total for same
customer for Jan 1-31, 2009 so that I can compare side by side.
I created a parameter to select invoices for the month of Jan 2008, but
how can I get both for 2008 and 2009. I could do a subreport, but I
don't know where in the report to put it or if this will work because I
am not getting any info.
Any suggestions?
Thanks in advance,
Dolores Hernandez
Software/Database Analyst
713-896-5178
dhernandez@energycr anes.com
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
box.
10. Click on OK
Hope this helps
Dale E. Schuerman
Senior Consultant
972-669-9603 (fax)
(website)
Any suggestions?
Thanks in advance,
Dolores Hernandez
713-896-5178
Attention:
by MailMarshal SMTP
